1980 Airpump
Old Jul 28, 2001 | 01:09 PM
F100Chris's Avatar
F100Chris
1980 Airpump
Hi all, due to the failure of several emissions related components and the relative scarcity of locating good used or even new ones, I have been thinking of just taking the whole airpump and related stuff out. I know this is not "legal" but the truck is basically a farm truck at this point and does not require emission testing. So, has anyone done this? The EGR looks to act like a big spacer for the 1bl Carter carb so maybe I can blank it off? The whole system (emission) is all mechanical so I am not going to have to fool any sensors. Help!
TIA, Chris
1980 Ford F-100
Old Jul 28, 2001 | 03:22 PM
82F100SWB's Avatar
82F100SWB
1980 Airpump
You can just disconnect the whole works and leave that spacer in place, or, if you can find a truck with a non-catalist emissions sticker, they have a carb spacer with only a vacum port for the PCV, and a nice stamped steel alternator bracket that doesn't have the air pump bracket on it. It's a while since I had my carb off, but, I'm pretty sure you can't just put in shorter studs and bolt the carb on,or I would have done it.
Evan MacDonald
82 F100 FlareSide 2wd
HD 300-6 9.5:1 CR
Clifford 270H cam
Hedman Hedder
SBC valved 66 240 head
Headlight Relays - Delanty Style
NP435(6.69 low)
3.55 Geared ARB'd 9"
31x10.50/15 Cooper Discoverer LT's
Old Jul 29, 2001 | 01:56 PM
82F100SWB's Avatar
82F100SWB
1980 Airpump
deronyv8
Sep 27, 2011 10:29 PM
59f100292
24
Jan 18, 2011 09:53 AM
chester460
Apr 7, 2007 07:35 AM
fordsfairlane
Jun 22, 2005 10:38 PM
