1998 explorer not staying runing!!!
Old Dec 7, 2007 | 11:31 PM
firemanbud's Avatar
firemanbud
my wife has a 1998 explorer that will not stay running whenever there is any kind of moisture in the air. i have replaced the wires and plugs. any suggestions?
Old Dec 8, 2007 | 12:44 AM
Bear River's Avatar
Bear River
Former ******
Are you sure that moisture is not getting into the gas tank. Run some Heet or some other gas dryer and see if that doesn't clear it up. When this no run condition occors, pull a spark plug and make sure it is firing.
Old Dec 8, 2007 | 07:40 AM
99f350sd's Avatar
99f350sd
Sounds like the IAC idle control maybe on the fritz. will it run with your foot on the gas?
Dick
Old Dec 8, 2007 | 10:06 AM
97limited5.0's Avatar
97limited5.0
i agree, when my IAC was on the fritz it wouldnt idle. it would only stay running with your foot on the gas. and after it stalls do you smell alittle gas???
Old Dec 10, 2007 | 10:45 AM
firemanbud's Avatar
firemanbud
yes it will run with foot on gas. ill try that thanks
ckrichard
Jul 13, 2023 08:59 AM
blake973
Mar 30, 2007 02:26 PM
Bob Cook
Dec 14, 2006 03:03 PM
fauxexplorer
Dec 21, 2001 04:47 AM
mlr51
Jan 15, 2001 11:21 AM
