1998 Explorer ABS Light
Old Mar 21, 2007 | 09:39 PM
blake973's Avatar
blake973
This past weekend, I replaced the front brake pads and turned the rotors on my 1998 Explorer XLT 4X4. After I got everything back together, the ABS light came on and stayed on. The brake fluid reservoir has been topped off and I disconnected one of the battery cables for close to a minute thinking that would reset the system. It didn't work. I even tapped the reservoir thinking the float was stuck. Any suggestions?
Old Mar 21, 2007 | 10:44 PM
Truck Issues's Avatar
Truck Issues
The sensor is not working properly. It's possible that you may need to turn the rotors again to confirm a flush turn, as a wobble in the rotor will cause the sensor to not detect. Also not that rotors MUST be rated for ABS.
Old Mar 22, 2007 | 09:01 PM
blake973's Avatar
blake973
Thanks. I'll give it a shot.
Old Mar 30, 2007 | 02:26 PM
blake973's Avatar
blake973
ABS Light
The problem ended up being the ABS sensor. While I was busting the rotors loose, I accidentally hit one of the wheel studs and drove it inboard and it cracked the sensor. $110 later and no light. My bad.
Hotairjunkie
Nov 4, 2014 07:49 PM
Redfridge
May 27, 2014 10:32 AM
txnotny
Dec 29, 2013 10:38 PM
mikulskn
Jun 26, 2013 11:23 PM
mismy68cougar
1983 - 2012 Ranger & B-Series
17
Jan 23, 2011 10:25 AM
