Vacuum guage,timing light, or ear
Old 08-17-2004, 11:24 AM
SShank42's Avatar
SShank42
SShank42 is offline
1987 2.9 in a Bronco II. Had distributor out and need help timing. Originally set the timing to spec 10 degrees btdc. Vehichle lacked power, put a vacuum guage on it and it said slow timing. So I set the timing up to about 14 degrees btdc, run better but still a little slow according to the vacuum guage. Motor has about 50,000 mile on it. So what do I go by? I think I need to set it up a little more for the same power that I used to have, but that will probably be about 18 degrees btdc. All adjustments were with the spout removed.
Old 08-17-2004, 11:38 AM
beastybronco's Avatar
beastybronco
beastybronco is offline
you can advance it as much as u want
the catch is if the timing is too advanced it will ping under load and u dont want that
Old 08-17-2004, 01:54 PM
mrshorty's Avatar
mrshorty
mrshorty is offline
Are you setting the base timing with the SPOUT unplugged? I have to ask because it's such common mistake. If you set the timing with the SPOUT plugged in, you will get severely retarded timing.
Old 08-17-2004, 03:23 PM
domc's Avatar
domc
domc is offline
Where's the spout?
I was trying to check my timing today on my truck and was wondering the same thing.
Where is the spout located in a 1990 F-150 5.8 Liter supercab engine?
Haynes manual shows a picture and says to look at the wiring harness that goes to the computer but I can't see anything like that in my truck that looks like a spout. I've got one on my Mustang so I'm familar how it all works.
Thanks,
Dom
1990 F-150
Old 08-17-2004, 04:15 PM
beastybronco
well i got a 88' 5.8 in a bronco and there is a convenient little plug right by the Ign control mod.
Old 08-18-2004, 08:12 AM
SShank42's Avatar
SShank42
SShank42 is offline
mrshorty, As mentioned in my original posts, "All adjustment were with the spout removed."
Old 08-18-2004, 10:50 AM
mrshorty's Avatar
mrshorty
mrshorty is offline
Sorry I missed that.
I've heard (and my 4.0 has this problem) of cases where the harmonic balancer gets rotated about the crankshaft so that the timing marks are no longer in the right place. Next thing I would suggest is to find TDC (compression) and see if the timing marks on the pulley match up with TDC.
Old 08-18-2004, 03:27 PM
beastybronco
i agree this will let u know if the timing you set is actual or not and is prolly a good idea
but regardless you will want to advance it to the point where it pings under heavy load and then back it off some so that it never pings
johnie ryall
20
09-12-2014 03:49 PM
SShank42
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
01-13-2006 02:31 PM
78oldsmokey
10-23-2005 04:05 PM
youngguy
13
03-24-2004 09:01 AM
fordsrus
08-03-2001 03:12 PM
Quick Reply: Vacuum guage,timing light, or ear
