Offroad & 4x4
quadzjr's build thread!!!
Old Feb 10, 2008 | 12:13 PM
  #106
crazyredneckanyhow's Avatar
crazyredneckanyhow
Hey quad i need a couple measurements on those SD coils. I need a diameter of the rod stock the springs are made from and a overall diameter of the coil itsself. Might use them on the crew.
Old Feb 10, 2008 | 09:08 PM
  #107
quadzjr's Avatar
quadzjr
just another Rockwell looser
Originally Posted by chrono4
it was the only "big head" picture I could find without getting a little risque
WOW
Old Feb 10, 2008 | 09:09 PM
  #108
quadzjr's Avatar
quadzjr
dont, they are too beef......i think they are right at 6" diameter.....ill check on the other stuff if you really need it...
Old Feb 10, 2008 | 10:14 PM
  #109
crazyredneckanyhow
Im gonna be runnin an oiler burner so i figure SD diesel coils and cage arms
Old Feb 10, 2008 | 11:00 PM
  #110
littleme13's Avatar
littleme13
sorry if this sounds like a newb ?? but ive heard mixed ideas. is there a reason why you choose to weld your subframe to the frame instead of bolting?? sorry ifyou explained but i couldnt find anything about it.
tony
Old Feb 10, 2008 | 11:38 PM
  #111
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
Quick question, Just how tall do you think this thing is going to stand say from the ground to the bottom of the door?
Old Feb 11, 2008 | 06:38 AM
  #112
quadzjr's Avatar
quadzjr
they are somwhere around 500-525 lb/sq" range......very stiff....
build you own arms!
Old Feb 11, 2008 | 06:39 AM
  #113
quadzjr's Avatar
quadzjr
tony
its easier and stronger.....and i never plan to lower it back so i dont care about bolting chit on....
Old Feb 11, 2008 | 06:40 AM
  #114
quadzjr's Avatar
quadzjr
??????????????????.......tall?????????????
Old Feb 11, 2008 | 09:25 AM
  #115
STGFordCrazy04's Avatar
STGFordCrazy04
before or after he stacks frames and adds a body lift?
Old Feb 11, 2008 | 09:36 AM
  #116
quadzjr's Avatar
quadzjr
sadly, it already has the body lift.....
but it will be gone when i remove the body!
Old Feb 11, 2008 | 07:44 PM
  #117
STGFordCrazy04
ADDs a body lift....as in 2
Old Feb 11, 2008 | 08:51 PM
  #118
quadzjr's Avatar
quadzjr
DOH!!!!!....nah seen a truck at mudfest with cut boat rollers as the BL>...
Old Feb 11, 2008 | 09:30 PM
  #119
detailsbydan's Avatar
detailsbydan
Hmm... Never thought about the boat rollers.... Thats a sweet idea. Thanks for putting that up here quad!
Old Feb 11, 2008 | 10:07 PM
  #120
quadzjr's Avatar
quadzjr
no comment!
so i got all the machine work for my front brakes done b700 rotors and f550 calipers....
