Hey quad put a twin stick on that 205 adn run a winch off the front output. With the twin stick you can disengage the rearoutput and throw all that 460 power to the winch
1st of all......i wouldn't know about how id do that.....2nd of all, the front yoke is about a inch away from the front crossmember......so id have to mod the crossmember that has already been modified and i dont want to do that.....i think my 12k winch with a block will be ok....
rusty rotors and hubs, dont worry i cleaned all the rust off.....
assorted parts on a rotor i ended up not useing......so if anyone needs 2 drilled and slotted rotors for your rockwells let me know...
drive slugs
my HIGH steer arm.....
all the bolts cleaned and ready to ready to assemble
spindles
While dana would be a good nickname for him...I was actually referring to the fact that deep down Nick really wants to be building a Dana axle instead of rocks.
