Just trying to get an idea of how often everyones truck goes into regen..I have a job 1 truck and before the reflash, she did a regen every tankful, so about every 250-275 miles or so. Now, with the new dpf and new flash, about every 500-600 miles she will regen. How about everyone else?
I have over 3xxx on mine and have not noticed it yet. But then agian 80 percent of my driving has been highway miles. Isnt there supposed to be something on the display on the dash that states a regen is in process?
regen is a mode where the exhaust system injects fuel into the dpf (diesel particulate filter) and burns the particles to clean the filter. You will notice the rpms rise to around 1200 at idle and increase slightly also when driving. im no expert and this is very brief but this is what has been explained to me.
Not exactly. It injects fuel into a cylinder during the exhaust stroke, which then travels to the DPF. No fuel line headin to the little bomb under the truck thank god. I believe that GM trucks have the type of system that injects fuel directly into the exhaust.
when i bought my 6.4 wastold it only regen out on the highway at a speed to protect any thing around the truck if it did it while it idled it would melt the the asphault i/m new on this so just what i wastold
If you have a pre turbo EGt installed you will see the regens as the EGT temps increase significantly. They occur more at city driving speeds. You may be surprised at how often regen takes place.
hell mine goes into regen all the time the motor actually sounds different to me.. i have 11000 miles on mine no one single problem to date.. 08 6.4 automatic f-250 4x4
