Sponsored by: Real Truck
Bouncing on the freeway
Old Dec 7, 2007 | 08:28 AM
jmaskew's Avatar
jmaskew
Does anyone else have a problem, when driving on the freeway, with bouncing? It feels like you are driving over small bumps (woopty doo's.... sp) in the road. The kids think its fun but my head starts to ache after a while. I hope I explained it well enough. Is there anyway of preventing it?
Thank you.
I posted in the wrong forum. How to I move it to this forum? 2003 - 2007 6.0L Power Stroke Diesel
Sorry!
Old Dec 7, 2007 | 10:22 AM
Ironhorse7's Avatar
Ironhorse7
What speed does it start at? Could it be the road surface (The right lane of I-40 and I-30 in Arkansas was REALLY bad a few years ago)? Tires need balancing? Need new shocks?
Old Dec 7, 2007 | 12:39 PM
2000silverbullet's Avatar
2000silverbullet
More than likely the concrete expansion joints on the freeway. I'm guessing it doesn't do it on asphalt though right? Do a search in this forum for "concrete". You'll see plenty of posts about it.
Old Dec 7, 2007 | 01:29 PM
redford's Avatar
redford
FTE Leadership Emeritus
You might try lowering your tire pressure a little, but be careful. If I take out too much pressure (15 pounds) I can induce the dreaded death wobble.
Old Dec 7, 2007 | 01:32 PM
jmaskew's Avatar
jmaskew
It starts when I get up to speed (55+) on the freeway. It only happens in some areas. I am thinking it's road surface. My '95 F250 did the same thing. I actually replaced the front shocks but it didn't do anything. I was just wondering if anyone else had experience it and came up with a solution. My tires are at 60psi, I was thinking about trying different tire pressures but I don't have a lot of time to do that right now. Thank you for the reply.
Old Dec 7, 2007 | 01:37 PM
jmaskew's Avatar
jmaskew
Yes it is on concrete. I'll do a search. Thanks for the info.
Old Dec 8, 2007 | 09:41 AM
BillyBob69's Avatar
BillyBob69
I have the same issue, but it only seems to happen on concrete when hitting the seams. Gawd I know the headache part tho...I went through ALOT of that when hauling a horse trailer to Minnesota and back from Colorado non-stop. I felt bad for the horse in the trailer on the way home...he must of thought we had a flat. But it was all smooth when on asphalt.
SkySkiJason
13
Jun 28, 2014 11:03 AM
Sycostang67
Apr 16, 2014 11:18 PM
SkySkiJason
Bio-diesel, Propane & Alternative Diesel Engine Fuels
17
Dec 19, 2013 09:41 AM
SkySkiJason
20
Dec 24, 2012 08:22 AM
Carl Lassiter
Aug 30, 2008 11:21 AM
