using fuel injected motor
Old Aug 15, 2001 | 11:00 PM
66fordpu's Avatar
66fordpu
I just bought a 66 ford 1/2 ton with a 352 motor. After reading about the "great" gas milage the FE's get I decided I want to find an inline 6. I have located a motor but it is fuel injected. How big of job is it to convert to EFI? Can I still use the motors and find an intake manifold and carb for it? Any information will be great.
Old Aug 16, 2001 | 02:07 PM
tetraruby's Avatar
tetraruby
Your post sounds like you want to convert the 6 from EFI to Carb, yes? Well, you'd need a carb, intake manifold, probably a new head without the injector holes and what else....what tranny are you using with the 352 - it may not bolt up the 6. There's a lot of work along converting from one engine to another let alone modifying the engine. But- someone here maybe interested in swapping some of the EFI stuff if you have all the electronics too.
Old Aug 16, 2001 | 04:25 PM
82F100SWB's Avatar
82F100SWB
To convert to carb from EFI, you will need the following: carb, intake manifold, Duraspark II wiring harness, dizzy , blue strain relief box, and an electric fuel pump, the fuel pump boss is there on the EFI blocks, but not cut and drilled. And, use the EFI exhaust manifolds, they flow much better than the log style single exit carb. exhaust manifold.
Evan MacDonald
82 F100 FlareSide 4wd
HD 300-6 9.5:1 CR
Clifford 270H cam
Hedman Hedder
SBC valved 66 240 head
Headlight Relays - Delanty Style
NP435(6.69 low)
NP 205
3.55 Geared ARB'd 9" & Trac-Locked TTB
31x10.50/15 Cooper Discoverer LT's
Old Aug 16, 2001 | 10:24 PM
truckzilla's Avatar
truckzilla
81bullnose
Jan 5, 2017 05:40 PM
1990ford150
May 30, 2016 10:51 AM
wtx66f100
May 23, 2015 09:14 AM
66shortbed
24
Mar 18, 2010 06:39 PM
creature66
Sep 3, 2003 10:21 AM
