tailgate stuck closed
Old Aug 22, 2001 | 04:52 PM
colonel_sanders's Avatar
colonel_sanders
one side is in and locked, but the other side isnt, and now it wont open or close, has anyone else had this problem?
Old Aug 22, 2001 | 08:34 PM
billyb's Avatar
billyb
probably the rod that goes to stuck side has come off. there are plastic clips that hold it on, and are subject to breakage.
you can either get to the rod from right behind the handle on pre 86 gates, or remove the panel inside the gate on later models . not sure of exact years , but most have ability to get gaste open if you need to. I just grab the rod with vice grips and tug to activate. to reinstall, you can get factory clips, but a peice of wire wrapped around the rod end and bracket seems to hold up.
Old Aug 23, 2001 | 11:34 PM
PAUL_2's Avatar
PAUL_2
Old Aug 26, 2001 | 10:10 PM
mudinford's Avatar
mudinford
What i did is leave it the way it is. Best theft detruant(sp) their is! I just found as long as you hold your mouth right and pull with the right fingers....its as easy as the latch its self. Its up to you. I dont mind it at all. The other guy had some good ideas as well....
Dan "Mudinford" MacDonald
Rather be pushing a Ford than driving a Chevy.
Like A Rock......In Water!
Plumber2002
Sep 1, 2015 06:19 AM
diesel jim
Dec 28, 2013 06:21 PM
jerryst
Dec 4, 2012 12:06 PM
Bigbruce
Mar 13, 2012 08:39 PM
