Sponsored by: Auxito
'01 F-150 electrical problem
Old Dec 6, 2007 | 05:01 PM
ishamp's Avatar
ishamp
It all started a while back. I drove it to the store and when I came out and turned the key, it did nothing. No lights, no clicking, nothing. Had it towed home and the tow truck driver took out his jump pack/battery tester kit and it jumped and started. And his kit said the battery wasn't charging. Sounds easy right? Well, just to be safe, I replaced the battery and the alternator. Ever since that day, the voltage intermittently spikes high. The battery meter pegs high. The windshield wipers speed up. The lights flash... etc. Then just goes back to normal. Then spikes again... and back to normal and so on. It seems to do it more often when I step on the gas. Any ideas?
Old Dec 6, 2007 | 07:12 PM
RCountryman's Avatar
RCountryman
Check the alternator to make sure its not over charging. I had a new one once on my camero that was overcharging and cause similar symptons. Also while your at it check your wires and cables to make sure all tight, no corrision and a good ground.
Old Dec 6, 2007 | 07:21 PM
chrisf250-460's Avatar
chrisf250-460
i would recheck the alternator.i replaced mine and it was overcharging,i had to get another one the first was bad.i had similar syptoms to the ones you describe
Old Dec 6, 2007 | 08:10 PM
steve(ill)'s Avatar
steve(ill)
make sure the alternator is grounded good, and motor ground to frame strap is not corroded. look at plugins and make sure no corrosion.. then alternator regulator might be problem.
cree92831
18
Oct 9, 2013 03:14 PM
2000-EB-EXPY-AWD
Mar 13, 2012 05:57 PM
jayc3169
Jan 27, 2012 09:15 AM
jayc3169
Jan 27, 2012 04:47 AM
mikehalll
Jan 12, 2007 09:26 AM
