Trans swap?
Old Dec 6, 2007 | 10:35 AM
ola1234's Avatar
ola1234
Trans swap?
Is it possible to swap a manual transmission from a 5,8l. gasoline to a 1991 automatic diesel?
The one on gas is from 1988. The diesel is 1991. Both extended cabs and 4WD.
Old Dec 6, 2007 | 11:08 AM
David85's Avatar
David85
Sorry, bolt patterns are different. Only a tranny that came off a diesel will bolt up to one (learned that one the hard way).
Old Dec 6, 2007 | 11:34 AM
ola1234's Avatar
ola1234
Thats what I found too, when I searched the forum. Just hoping I was wrong.
It is impossile to get a donor-truck here in Norway with manual trans/diesel and a reasonable price. Maybe I should import one from the USA...??::
Old Dec 6, 2007 | 12:45 PM
Dave Sponaugle's Avatar
Dave Sponaugle
No idea what shipping would be, but I am sure you could find a salvage yard that would ship you one.
Old Dec 6, 2007 | 12:46 PM
David85's Avatar
David85
New ZF 5 trannies usually go for 1500-2500 USD. But there are the odd ones used on Ebay for less. I don't think you really need to import a whole donor just to get the manual tranny, its not like north america is just down the street($hipping). You can probably have a shop modify your driveshaft, and and the clutch components can be ordered seperately, as there are many online auto wreckers.
Old Dec 6, 2007 | 12:50 PM
Dave Sponaugle
As I remember he is an engineer on a ferry, so he probably has all the contacts for machine shops that he would need for driveshaft work.
A hydraulic clutch pedal assembly would also be needed, but if the gasser uses a hydraulic clutch it would probably work.
Old Dec 6, 2007 | 02:12 PM
j-redsjeep's Avatar
j-redsjeep
are you talking a 4 speed, if so yes with a different bell housing.
if you are talking a zf-5 that "can" be done to. it has to be a big block and there will be some machining involved.
Old Dec 6, 2007 | 03:37 PM
ola1234's Avatar
ola1234
Yes, still working onboard a ferry.
For now I am just playing with the thoughts about doing a swap. My auto works just fine. But I am mostly driving at small roads at low speed. I think the auto works fine when I am at the highway, but I am not happy with it when it is often in 1-2-3, without lock-up. As soon as the speed is high enough for lock-up to engage, it is ok.
Shipping-costs are about 3000 $. So then I think I would import a driveable truck in the price-range 1500-3000 $. ( I am not sure my wife thinks this is so very smart..!..) then I have a spare engine to overhaul and paint.
Plus a lot of other parts.
Old Dec 6, 2007 | 04:19 PM
shorthair's Avatar
shorthair
If a person understands that most anything can be possible, many are not feasible or economical. Why not if you are going to import a running truck then make it another IDI.
Old Dec 6, 2007 | 08:11 PM
David85's Avatar
David85
If lockup is your only beef with the E4OD transmission, you can install a manual override switch kit, or if you really want to go all out, you can completely replace the stock computer with an programable aftermarket one (which is what I run).
