are you talking aboiut he little wire that runs along the injector harness\glow plug if im thinking or the same harness it only has like two wires right?
Unplugging the EBPV does not harm the truck. It just takes longer for the combustion temps and oil/water temps to get warm. When I turn mine on my egts stay around 400 while turning it off the temps stay around 200 or so.
it is usually when its warm. because the truck has a higher idle when its cold. and it has this little shake but it stops and levels out but the idle is still there
