whining fuel pumps
Old Sep 3, 2001 | 03:47 PM
vinster's Avatar
vinster
whining fuel pumps
When i got my f-150, i noticed a whine coming from underneath the bed which later determined the sound came from the area of the fuel tank, also when i switched to the front tank the noise then shifted to that area. assuming it's the pumps, are there rebuild kits?, or do i have to buy new pumps alltogether? I had changed the fuel filter when i found it was impossible to blow any air through it, could this hve stressed the pumps causing them to make the noise?
Old Sep 3, 2001 | 11:11 PM
PAUL_2's Avatar
PAUL_2
whining fuel pumps
Its hard to gauge a failing pump by the noise those particular pumps make . It seems the hotter it is , the worse the noise is that they make . A clogged fuel filter would definetly place an undo load on the pumps . Check your fuel pressures , both static & running , see how quickly the pressure builds & holds , Thats a more accurate measurement of how well a fuel pump is doing . You should notice the fuel pressure goes to at least 40 psi as soon as the key is turned to run . Engine running pressures should be in the 50 Psi range .
Old Sep 4, 2001 | 08:12 AM
chip58's Avatar
chip58
whining fuel pumps
Pat Taugher
Dec 28, 2014 05:26 PM
wisecountybuck
2004 - 2008 F150
Feb 29, 2012 10:37 PM
BCHauler
Dec 10, 2009 12:46 PM
emmagator
Mar 25, 2008 06:42 AM
rlh
1978 - 1996 Big Bronco
Dec 17, 2003 06:20 PM
