95 F 150 trans problems
Old Dec 5, 2007 | 11:08 PM
jasper1's Avatar
jasper1
I recently bought a 95 F150, 5.0 , 4R70w, 2 wheel drive. The trans acted crazy for about 10 days, then stopped pulling altogether. I recently located a 4R70W from a 96 F150, low miles. Questions are:
1. Where the heck is the PCM located?
2. Will the 96 trans work in my 95?
3. Is the PCM different between 95 and 96.
Thanks to all for your help! I'm anxiously awaiting your help. (It's rough using my Buick for a work truck!) Jasper1
Old Dec 6, 2007 | 06:24 AM
subford's Avatar
subford
Drivers kick panel. You get at it from under the hood.
Image:
http://i54.photobucket.com/albums/g91/subford/Electrical/EEC%20PCM/PCMlocation.jpg
Do not know for sure but think it would.
Yes, the 95 has a 60-pin connector and the 96 has a 104-pin connector.
Old Dec 7, 2007 | 08:52 PM
jasper1's Avatar
jasper1
95 F150 trans problems
Jasper1 here! Thanx to subford for his quick assistance. I have this 95 F150 with the 4R70W trans, which is shot. I can buy a 96 4R70W for a good price, but need to know how much hassle it will be to do the swap.
Given that the PCM's are different what will happen if I just try to "plug and play"? Will THE 96 trans electrical plugs fit the 95 harness? If so, will it work OK with the 95 PCM? Oh yeah, I only have about 2 days to make the deal on the 96, so HELP!!!! asap. Thanx, Jasper1
Old Dec 7, 2007 | 09:50 PM
subford's Avatar
subford
Looking at the two plugs for the 1995 & 1996 at the Transmissions they have all of the same wire numbers and colors in the same places in the plugs. The plugs look the same also in the diagrams.
The 1995 PCM should work also.
That said what I would look for is if they have the same size extension tail shaft housing.
I do not know on these years but in older transmissions the Van and Truck had different shift arms. May not be a problem with a cable shift. Did the 1996 transmission come out of a truck or a Van?
Old Dec 8, 2007 | 07:09 PM
jasper1's Avatar
jasper1
95 to 96 trans swap
Thanks again to subford for the info! You saved me God knows how much time trying to figure this out. I'll keep you posted as to how the swap works out. Later, Jasper1
Old Dec 9, 2007 | 12:03 PM
jasper1's Avatar
jasper1
F150 trans
I forgot to answer subfords question; this trans is from a pickup. Thanks, Jasper1
Old Dec 22, 2007 | 01:57 AM
jasper1's Avatar
jasper1
OK, so I installed the 96 AODE in my truck. As subford said, all wiring pigtails were the same. I pre-filled the torque converter. Now it won't "pull" unless I rev it to approx. 4000 rpm, including in reverse. Any ideas????
Old Dec 22, 2007 | 05:42 AM
subford's Avatar
subford
Sounds like low line pressure, you need to put a gauge on it to see what you have.
Is this the same problem that you had with the other transmission?
If so you may have a wire or PCM problem.
How did you determine that the old transmission was bad?
Did you get a guarantee with the transmission?
Could be a bad:
1. Pump
2. Seals
3. PCM
4. Solenoid valves
5. Wiring open in one of the circuits from PCM to the Transmission (plug pins, cut wire)
Old Dec 25, 2007 | 04:05 PM
jasper1's Avatar
jasper1
Cool 95 F150 trans problems
Hooray!! Subford, your damned near a genius. I had leaks in a line which caused my carefully measured trans fluid to be low. I fixed the leaks, brought the fluid up to proper level, and the tranny works perfectly. Unfortunately, my 16-year-old daughter, whose had her license for about a month, decided that messing with her cell phone was more important than navigating our driveway and slammed the left front corner into a tree the day I got it fixed. It's always something! Anyway, thanks for the help! jasper1
outdoorfan
May 27, 2016 10:08 AM
stuart9534
Ford Truck Parts for Sale
Apr 6, 2016 10:55 AM
f150truckguy
May 29, 2014 12:27 AM
gopher2
Oct 16, 2009 12:55 PM
shaggy1979
Aug 28, 2004 03:57 PM
