Hard To Start???
Old Dec 5, 2007 | 10:33 PM
gman536's Avatar
gman536
Hard To Start???
1995 7.3
About 130k miles.
Sometimes it takes a long time to start.
It's putting out ALOT of smoke, but then it takes several mins to start.
I turn it off and let the plugs glow longer, but it doesn't make a differance.
I just had a couple of glow plugs replaced, the glow plug's relay and a wiring harness.
I replaced the cam sensor about 15k ago.
The shop is just guessing and with my money!
Have any of you ran into this one?
Thanks, Garett
Old Dec 5, 2007 | 11:17 PM
the grimlin's Avatar
the grimlin
Sounds like your heui pump is loosing it's prime or is going out. Your injector O rings could be bleeding off the hi pressure oil. Look to see if you have oil in your fuel or fuel in your crank case.
Old Dec 5, 2007 | 11:34 PM
dinikin's Avatar
dinikin
What is the fuel pressure at the shradder valve, at start Up and Idle.
Also I have put a little info in other tread
check it out.
https://www.ford-trucks.com/forums/6...ld-driver.html
Forgot to ask. Do you have hard start condition all the time, or only cold????
Originally Posted by gman536
1995 7.3
About 130k miles.
Thanks, Garett
Old Dec 6, 2007 | 10:00 AM
gman536's Avatar
gman536
Hard to start at 1st start up only.
Old Dec 6, 2007 | 11:27 AM
Cuda_jim's Avatar
Cuda_jim
Are you shutting the truck off right after you get it started and then restart with it still cold or are you letting it get up to temp and then it's OK?
Next cold start (over night) check the level in the HPOP. If it's low the check valve is leaking. Come back here and we can walk you through the repair.
Garett
Jun 10, 2012 06:35 PM
Chance_Thomas
16
Feb 28, 2009 11:11 PM
Chance_Thomas
Jul 24, 2008 09:00 PM
garettanderson
Oct 14, 2006 08:44 PM
StillaKilla187
Jan 30, 2006 02:35 PM
