Sponsored by: Real Truck
4x4 knob lighting
Old Dec 5, 2007 | 05:26 PM
1975StroppeBaja's Avatar
1975StroppeBaja
4x4 **** lighting
I did a search (admittedly... a quick one) and didn't find anything about this...
Is there supposed to be lighting behind the 4x4 **** on the dash? Similar to the lighting on the heater controls? In my '04 I cannot see the 4x4 **** at night with the headlights on. I was wondering if this is normal or if I have a bulb burnt out or something?
Thanks in advance!
Jason
Old Dec 5, 2007 | 05:57 PM
jeff7825's Avatar
jeff7825
I don't think there is any lighting behind the **** itself, just behind the 2wd, 4x4 high and low. That's the way it is on my truck.
Old Dec 5, 2007 | 06:16 PM
1975StroppeBaja
That's good to know... I don't have any illumination in that area.
Thanks!
Old Dec 6, 2007 | 06:37 PM
Topbob's Avatar
Topbob
4x4 switch light.yes in '06
My '06 SD-250 4x4 switch is backlighted; don't know about your '04.
This is one heck of a site, isn't it? Everything from engine engineering to
dash light info.
bob
Old Dec 6, 2007 | 07:24 PM
1975StroppeBaja
dash light info.
bob
Yeah it is! I lurked on this site for a long time and finally got my SD and started posting.
So, I guess my next step is to take apart the dash as described in some other threads and see if I can find a blown bulb. Unless anyone has had luck removing the little 4x4 **** panel without pulling the dash apart???
Old Dec 6, 2007 | 07:36 PM
Beerstalker's Avatar
Beerstalker
Once you get the dash panel out you will see how to get the 4x4 switch plate out. I would not try removing it without taking the dash panel out. Search through my old posts, as I have given instructions on how to remove the dash panel a few times.
BTW I'm pretty sure the writing on my 99 F250 XLT and 07 F350 Lariat 4x4 switches lit up with the interior lights. I'm not sure if it is a replaceable bulb though, you may have to replace the whole switch.
Old Dec 9, 2007 | 04:35 PM
1975StroppeBaja
Well, not sure what's going on but the writing above the **** lights up as of last night
It snowed a bit here last week and I had it in & out of 4x4 half a dozen times so maybe I shook something behind there and its working again.. for now?
Anyhow, I guess I'll just go with it until they go out again.
Thanks again for all the input.
Old Dec 13, 2007 | 07:33 PM
1975StroppeBaja
Ok... the lights behind my 4x4 **** went out again so I took it apart. I found that the bulb is burnt out. I see +12V on the terminals with the headlights on, but no bulb lighting. So... has anyone ever replaced this bulb? It looks to be replaceable. It comes out of the switch assy with 1/4 turn of a screwdriver. See pics below.
Old Dec 13, 2007 | 09:56 PM
Hootbro's Avatar
Hootbro
That is probably going to be a dealer only bulb.
I thought it was a LED buy my schematic shows it to be a bulb lamp type.
Old Dec 13, 2007 | 10:33 PM
1975StroppeBaja
I'm gonna check with the dealer tomorrow and see what they say.
Yeah, it looks alot like an LED but its just a regular bulb with a green jimmy hat on it
Old Dec 14, 2007 | 08:29 AM
FordTruckNoob's Avatar
FordTruckNoob
They sell LED replacements. Look here:
http://www.superbrightleds.com/specs/74_t15.htm
Old Dec 22, 2007 | 08:16 PM
1975StroppeBaja
Ok... here's the story as I see it, in case anyone's interested. The name for these type of 1/4 twist bulbs is "neo-wedge" which is apparently very popular for normal instrument cluster type illumination in cars these days. The company that built these particular bulbs for Ford is "JKL Components Corporation".
The 4x4 **** version of this bulb is an oddball since it is taller than the typical bulbs you'll find if you search for "neo-wedge" bulbs. It's also an oddball because the typical neo-wedge bulbs that I've found have the contacts in the wrong area. The replacment bulbs have contacts in the area shown by the blue arrow in the pic below. The Ford bulb has contacts in the area shown by the red arrow. You can see that better in the third pic that I posted above.
I ended up finding a bunch of the bulbs pictured below on ebay. They are *almost* an exact replacement, except for the contact location problem. So, I simply removed the dead bulb from my original housing, inserted a bulb from one of my spares, placed the green cap on, and it works like a charm.
So, if anyone ever has a problem with this bulb (and possibly the bulb that lights the headlight switch, I haven't looked?) shoot me a pm and I can help. If you're ok with doing what I did (remove dead bulb/reinstall new bulb) then I can mail you replacements for $2 each. I'm going to see about modifying these bulbs to be direct plug-ins but I don't have the time right now to work on it. I think it should be fairly simple.
Whew, so that's it. Everything I know about the 4x4 **** bulb
Old Feb 19, 2018 | 11:38 AM
SportTracer's Avatar
SportTracer
7th Gear
Headlight Switch bulb for 2007 Explorer Sport Trac
This may work for you. The following bulb worked in a 2007 Explorer Sport Trac headlight switch: http://audioxpress.org/listing/05-06-07-08-09-ford-mustang-headlight-switch-light-bulb It had a blue rubber covering over the bulb, so I removed it before installing.
Also here is a link to the bulb manufacturer. It has a lot of similar type bulbs with specifications, drawings and dimensions, but not sure which bulb it is:http://www.jkllamps.com/incandescent/neo-wedgelamps
Old Feb 19, 2018 | 01:04 PM
1975StroppeBaja
Cool! Thanks for the link.
Good to see that some options have become available since I was working through this years ago.
Old Feb 19, 2018 | 01:16 PM
SportTracer
7th Gear
Thank you for giving me ideas on my internet search. If you keep plugging in, you can usually find what you need with people like you who are willing to take the time to post answers!.
Highboy4x4
Dec 6, 2016 11:27 AM
Bob_91SC4x4
Oct 11, 2015 10:28 PM
oracle
Apr 28, 2013 10:23 AM
xc4jokestomper
May 21, 2011 09:02 PM
