300 stumbles when cold
Old Sep 3, 2001 | 10:16 PM
DrFord's Avatar
DrFord
when I first start my 88 300 it seems to have a difficult time maintaining a steady idle. the engine vary's from 900-400- rmps. also when I try to take off it just seems to sputter, and I really have to ride the clutch. it also does the same thing when it has less than 1500 rpms and I give it gas ( i.e shifting from 2nd- 3rd). all of this disapears once the engine is warm. I have checked the TPS and voltage readings seem to be in the norm. I am thinking that it may be a engine temp sensor that is suppose to adjust fuel mixture depending on engine temp. any other ideas. or where would this sensor be located??
Old Sep 3, 2001 | 11:18 PM
PAUL_2's Avatar
PAUL_2
The coolant temp sensor is located on the pipe from the thermostat housing , Its cold resistance should be in the 37 to 58K Ohm range with the coolant temp in the 50 to 70 Deg range . Normal operating temp you should see readings in the 1 to 3K Ohm range . Check the Air Temp Sensor as well , its located on the Number 1 intake runner of the lower intake , Its Ohms readings should be the same as for the coolant temp sensor , Maybe a little higher when hot because the air temp in that area will likely be less than the coolant temp .
Old Sep 7, 2001 | 10:35 PM
DrFord's Avatar
DrFord
I finally got a chance to test my sensors today. when the engine is cold I am only getting about 27 ohm resittance instead of 37. this is on both sensors. when they are plugged in I am only getting about 2.66 volts on them (a 5.00 volt ref.). are theese readings normal?? or could this be my problem with the cold engine.
Old Sep 9, 2001 | 12:00 AM
Herman's Avatar
Herman
27 Ohms, or 27 K ohms? If it is 27 ohms it is your problem Herman
Old Sep 9, 2001 | 01:46 PM
DrFord's Avatar
DrFord
Well ok sorry about the confusion. it is actually 27K. this reading is the same for both the sensors. are there any other sensors that I should check??
Old Sep 9, 2001 | 07:13 PM
rpickle's Avatar
rpickle
muldrick
1983 - 2012 Ranger & B-Series
20
Dec 16, 2010 02:46 PM
kcyuba
Apr 16, 2009 12:04 PM
DrFord
Nov 28, 2007 11:30 AM
tndiesel
23
Jul 22, 2007 03:54 PM
somairot
Oct 10, 2006 09:09 AM
