1975 4x4 390 to 460 swap
Need some info on swapping a 460 into a 75 highboy. The truck had a 390 in it. I am using a bellhousing from a 400 M and the clutch from the 390. I have been told that there is some way of making the 390 motor mounts work. If anybody has any pics or input on this I would appriciate this as I do not want to spend $275 for the L&L kit.
Thanks,
Doug
Thanks,
Doug
Did the same swap, bought new 360/390 mounts for the highboy, lined them up on the 460 block, drilled one hole. Installed with original engine towers, fit nice=got the info. from this site! Had to make room for the bolt head in the rubber, just used a small holesaw-removed the rubber, and it worked. I used ex. manifolds from a supercab 2wd.
Haven't attempted headers yet.
Note: I changed my whole drivetrain from standard/divorced T-case, to auto/married.
hope it helps, and sure beats big $$
crazed87bronco
27
04-22-2011 12:30 PM
F350moneypit
08-23-2009 06:29 PM
1ole4d
11-03-2006 08:39 AM
1975, 19754x4, 390, 390460, 460, 4x4, 75, 76, 77, 77ford390460swap, c8vy6038b, conversion, ford, powerstroke, swap
