4 speed to a C6 swap
if the 83 had either a 351M, a 400, or another 460 then the C-6 should bolt right up to the 460... to bolt it to the 390 you'll need an adapter plate and they are expensive.. if the 83 had any engine other than those I already said, then you'll probably have the wrong bellhousing bolt pattern.......... You guys that know more than I do, please correct this if I'm wrong
X2...
FE engines have their own unique bellhousing bolt pattern
335/385 Series have their own (that would 351M/400/429/460)
Small blocks with Inline -6 cylinders
Y-Blocks
Flatheads yadda yadda yadda
For an FE C6 you'll have to source one from an FE, no other financially responsible way around it.
Josh
Y-Blocks
Josh
250-highboy-76
04-27-2005 06:17 PM
71FoMoCo
03-21-2003 07:10 PM
