Please help me settle something..
Old Dec 4, 2007 | 09:48 PM
  #31
PowerStrokeHD's Avatar
PowerStrokeHD
Originally Posted by Max66
Could it be an option in warmer climates? I will try it with my zip and let you know. Maybe he meant it is a standard item for him. I will get back to you.
The block heater is standard in all PSD's, it is the cord that is optional in most states and standard in a few states that Ford considers cold weather states.
Old Dec 5, 2007 | 01:57 AM
  #32
Max66's Avatar
Max66
I was wondering why it was a $35.00 option.
Old Dec 5, 2007 | 12:58 PM
  #33
rotun's Avatar
rotun
Reads ***** rules!
I found this re: harness installation from dealer. Wish I could post attachments in here, it's pasted from the .pdf.
F-SUPER DUTY 250-550 6.0L DIESEL ENGINE BLOCK HEATER WIRE
HARNESS INSTALLATION
SERVICE PROCEDURE:
2005 Model Year F-Super Duty 250-550 Engine Block Heater is optional however the heater element is installed
with all 6.0L Diesel engines. The following instructions are used to add the block heater function by installing the
wiring harness to the heater element.
KIT - ENGINE BLOCK HEATER 5C34-6A050-AA
Part Number Description Quantity
5C3T-6B018-AB Wiring Assembly-Engine Block Heater 1
SK 5C34-6A050-AA Instruction Sheet 1
Old Dec 5, 2007 | 02:26 PM
  #34
jmaskew's Avatar
jmaskew
Originally Posted by LvTitan
what a tool that mechanic is. that heater draws like 1100 watts and it'll be as hot as it's ever gonna get after only 3 hours, so leave it on the time my friend.
personally i'm too lazy for this, so i actually do plug mine in when i get home and leave it on all night, but actually with the new injectors and new batteries, my truck fires up perfectly every morning now without it, even though it's actually colder out now.
On both of the Ford diesels I have owned (1995 & 2004), I plugged them in all night... even in Vegas were the temp the other morning was a whopping 40F!! I have noticed the block heater on the '95 warmed the block a heck of a lot more than on my 2004. Has anyone else noticed this or maybe I just have a faulty block heater.
Old Dec 5, 2007 | 07:26 PM
  #35
Brian460's Avatar
Brian460
Brian
If you start it allot at that temp do you go through batteries quicker? Or have you had any problems with the batteries. I would say it takes a while to warm up at that temp? I think it is just easier on the motor and all components if you plug it in.
It for sure cranks slower at those temps. I am not in that climatge all the time (I travel for work). Definately takes longer to warm up at those temps I start it and let it fast idle for 10-15 min before driving. I am sure you are right about being easier on engine and components, but when you are in the middle of nowhere with no way to plug it in you are just out of luck.
Surprisingly I just took took the factory batteries out and replaced them a month ago and the truck is an '03.
Old Dec 5, 2007 | 08:42 PM
  #36
Max66's Avatar
Max66
I feel your pain. When I head to the mountains in the winter there is no where to plug in. So i just make sure my batteries are in great shape. I am a little bit of a fanatic and I just changed my batteries in my 2006 to the yellow tops.
Old Dec 5, 2007 | 09:16 PM
  #37
BPofMD's Avatar
BPofMD
Veteran: Navy
For those that state "it cranks slower" at low temps, what weight oil are you using? If it's THAT cold where you are, I'd be using a 5w40 or 10w30 as the manual says....
dwilli1969
Sep 21, 2016 05:35 PM
Leatherneck007
Aug 10, 2014 08:57 AM
Lastwagen
General Diesel Discussion
Jul 17, 2013 03:33 PM
big poppa
23
Nov 17, 2010 10:30 AM
lakewood
Dec 15, 2009 01:59 PM
