engine sizes
Old Dec 4, 2007 | 06:02 PM
jagermeister486's Avatar
jagermeister486
engine sizes
what size engines came in the 76 ford f250, i was told the one i am lookin at has a 360, they are not sure tho, it is 2wd and an automatic
Old Dec 4, 2007 | 08:20 PM
STGFordCrazy04's Avatar
STGFordCrazy04
360FE was a very common engine in 73-76 trucks. You can tell that its an FE engine because the valve cover bolts to the heads and to the intake. Maybe a better way to explain it is that the valve cover covers approximately 3/4" of the intake. Be very wary if the seller tells you its a 390. Its impossible to visually tell the difference between the 2 engines because a 390 is a 360 with a longer stroke.
The other engine choices were 300 inline 6 and 302 V8 if Im not mistaken.
Old Dec 4, 2007 | 08:42 PM
gnwalker's Avatar
gnwalker
must be FE, no 302 in pick ups til '78
Old Dec 4, 2007 | 08:54 PM
76 F-150 390FE's Avatar
76 F-150 390FE
its either a 360, 390, or 460 all 3 were offered in 2wds the only v8 in 4wds was a 360
Old Dec 5, 2007 | 01:51 PM
75crewcab's Avatar
75crewcab
2wd came with 302 engines. My dad had a new 72 f150 2wd with 302.
Old Dec 26, 2007 | 02:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Sorry, incorrect = The 302 engine was introduced in F Series trucks in 1969.
Used in F100's only thru 1972.
1969/79 302 VIN engine code = G.
1973/76 V8 engines (VIN engine code in bold type): 302 G / 360 Y / 390 2V H / 390 4V M / 460 A or J
1977/79 V8 engines: 302 G / 351M H / 400 S / 460 A or J
240 I-6's used 1973/74 / 300 I-6's used 1973/79
Old Dec 26, 2007 | 02:54 PM
73f100shortbed's Avatar
73f100shortbed
That's not true
