Sponsored by: Auxito
multi function switch 2000 F150
Old Dec 4, 2007 | 04:47 PM
falcn63's Avatar
falcn63
Does anyone know the procedure or have a manual that shows the replacement of the multifunction switch (turn signal switch) on a 2000 Ford F-150? I wouldn't mind going out and buying a Haynes manual or something similar if I knew if it would show this, but of course they are all sealed and you can't look at them before you buy them. If anyone has ever replaced one, I'd love to hear about it. Thanks much!
Old Dec 4, 2007 | 08:24 PM
Gevans17's Avatar
Gevans17
Multifunction switch R and R
check your private messages
Old Dec 5, 2007 | 06:16 AM
projectSHO89's Avatar
projectSHO89
Multifunction Switch removal and Installation
It's pretty easy.
1. Disconnect negative battery cable
2. Remove lower shroud cover
a. Unscrew and remove the tilt lever, if equipped
b. Remove three screws
c. Unclip the lower cover from the upper cover and set aside
3. Remove the ignition key cylinder by turning the key to RUN, depressing the release pin under it with a punch, then pull the cylinder out.
4. Remove upper cover
5. Remove the MFS mounting screws (they're often Torx heads)
6. Disconnect the electrical connectors and remove the switch.
Installation is the reverse.
Steve
28
Mar 8, 2023 05:28 PM
homerunswing
1997 - 2003 F150
Aug 30, 2016 04:58 PM
boxerdoglover
Aug 27, 2007 06:11 PM
F150owner2u
Jun 21, 2006 03:07 PM
mep123
Oct 23, 2003 10:50 AM
