I have 1 or 2 lights out in the cluster, looking in my Chilton book it appears I need to pull the radio and the finish panel around the cluster, the radio seems to be my problem, I've heard you can buy a tool or make one out of a coat hanger by bending a "U" in the hanger....I assume the "U" acts as a handle because I see 4 small holes around the radio, 2 on either side of the top & the bottom that a "U" couldn't fit into, my question is how to perform the task and which holes to go for, top or bottom?
You need to stick the "U" shaped wires in both top and bottom and they will release the radio. Once you stick them in you should be able to pull the radio right out.
Thanks Yukon, I assume if a guy wasn't dumb like me, he would replace all the lights, Right?
Just to let you all know the flood waters (SW Washington) are going down and the suns out, the 4 foot creek at the bottom of my place was 100 feet out of it's bank!!!!
glad to hear that. its been on the news all day. Its surprising that there was that much flooding from 4 inches of rain. They must of forgot something important.
Lee's Camp in the coast range got 10 inches, where I'm at it was just all the tributaries feeding down into my little creek and the lay of the land that caused my little flood, 100 ft out out the stream bed in 10 arces don't amount to much in the bottom land.
Inerstate 5 is still under 5 feet of water, south of Olympia. There is a 20 mile section closed.. There some cities West of Seattle that got over 11 inches of rain in 24 hours.. Sure glad I have web feet to get around.. !
