Ok where is it?
Old Sep 26, 2001 | 07:16 PM
vinster's Avatar
vinster
Ok where is it?
I was advised i could clean my egr valve until i can replace it and it might improve my situation a bit (engine light..yeah it came back on..) but where is it located? how would i remove it? any special things i need to know? thanks in advance. -vin 90'f-150 xlt lariat I-six (4.9) efi
Old Sep 26, 2001 | 09:05 PM
larry derouin's Avatar
larry derouin
Ok where is it?
Look on the INTAKE MANIFOLD behind the throttle body.
it will look like a small pot with a flange on the side and a pipe on the other with a large nut. Vacuum line comes off the pot side.
You'll need a 1/2" socket and a 1-1/16" open end slugging wrench.
Make sure you use plenty of PB Blaster (or equivalent) on the large nut. This is a flare fitting from the exhaust and will have a bit of rust on the threads.
Get a new gasket from the local auto store (about $2.00). clean the EGR (INSIDE the pipe end) with a small bottle brush and carb cleaner.
Have fun!
Larry
Old Sep 26, 2001 | 10:33 PM
Herman's Avatar
Herman
Ok where is it?
vwovw
Apr 19, 2017 08:29 PM
91ford7.3
Jul 9, 2016 02:06 PM
RUSTY_BUT_TRUSTY
Oct 11, 2015 04:42 AM
jake00
Sep 7, 2015 11:31 PM
Trevor1
1978 - 1996 Big Bronco
Jul 19, 2006 02:31 PM
