My 96 250 with 7.5 is jumping in and out of nuetural. when in drive. i topped off fluid but to no avail. no new engine codes. hope there is an easy fix.
i know this is might be stupid question, but i've been storing a newely rebuilt tranny out of an 96 bronco 5.8. there's no way it will bolt up to a 7.5 is there?
sssiiiggghh. i guess its time to trade it in for something newer,.
Being as a E4od is only for trucks, to big for anything else. I think it will bolt up but a minute or two with a tape measure will tell ya. Also check with a bone yard, their interchange book will tell you and also tell ya which flywheel to use from each one.
The older 351, 400 and 460 bell housings patterns where the same.
The tranny from the 96 351 will not bolt up to the 460, the 351m and 400 trannys will bolt up, the 96 351 is a windsor small block, the 351m is a 335 series big block
