Base timing 96 7.5
Old Jul 15, 2011 | 12:10 PM
kevinb98's Avatar
kevinb98
Base timing 96 7.5
What is the base timing for a 96 7.5 ford f250.The service guy at ford says it's 0 but it doesn't run good at that setting.I set it with the spout connector removed.The sticker says there's no adjustment but there is.
Old Jul 15, 2011 | 12:40 PM
subford's Avatar
subford
It is 10 deg BTDC with the SPOUT removed.
Old Jul 15, 2011 | 03:58 PM
rickybobby1977's Avatar
rickybobby1977
I am new to this. What is the spout?
Old Jul 15, 2011 | 04:15 PM
subford's Avatar
subford
Spark Output (SPOUT): Desired spark timing information sent from the PCM to the ICM.
There is a shorting bar that you remove to disconnect the computers output to the ICM when using the timing light to set base timing.
Then the computer assumes 10 deg BTDC base timing and when the SPOUT shorting bar is back in it will advance the timing from that point.
Fordziller
1983 - 2012 Ranger & B-Series
Mar 3, 2017 06:52 AM
three.on.the.tree
Sep 23, 2016 08:03 PM
want2sobad
Jan 31, 2016 10:08 PM
jerrymlr1
Jul 31, 2014 09:03 PM
Nighteyez
N. California Chapter
Nov 30, 2006 06:54 PM
