92 Ford F-150 Flareside engine problems
Old Nov 27, 2007 | 08:37 PM
ford150man's Avatar
ford150man
Unhappy 92 Ford F-150 Flareside engine problems
I have a 1992 Ford F-150 Flareside. It started missing and smoking the other day.I took out all the plugs and put in new ones. It looked like one was bad.This did not help. I bought new plug wires, cap and rotor and changed them. This didn't help either.It seems to keep filing out one plug. It appears to miss the worst at low RPM'S.When i press on the gas to go faster when it is missing and sputtering, it starts smoking pretty bad.The check engine light comes on but does not stay on, it just blinks on and off every so often.Does anyone know of anthing else that could be causing this? Thanks for your help!!!
Old Nov 27, 2007 | 08:45 PM
flareside_thunder's Avatar
flareside_thunder
Make sure you've got your 7 and 8 wires routed correctly...wish i had a schematic....if you don't they'll cause it to miss but that probly wouldn't explain the smoking.Have you changed your PCV valve?it's on the passenger side valve cover on the end closest to the firewall and it can be tricky to get to.Luck
JR
Old Nov 27, 2007 | 08:56 PM
Moore558's Avatar
Moore558
What color smoke is coming out the tailpipe? Also do a scan for codes. Use this to help. http://www.fordfuelinjection.com/?p=13
Old Nov 27, 2007 | 09:00 PM
ford150man's Avatar
ford150man
The smoke is a blue color. No, didn't do a code check yet. Thanks!
Old Nov 27, 2007 | 09:11 PM
Moore558's Avatar
Moore558
Which plug are you fouling out?
Old Nov 27, 2007 | 09:14 PM
ford150man's Avatar
ford150man
It's the back plug on driver's side.
Old Nov 28, 2007 | 02:33 PM
ford150man's Avatar
ford150man
Cool
JR
Just changed the PCV VALVE today. The darn thing is still running rough and smoking. I can't figure it out.
Old Nov 28, 2007 | 02:44 PM
TheRoadVirus's Avatar
TheRoadVirus
Unfortunately it sounds like your number eight cylinder is done for. The PCV dumps pretty much whatever it re-circulates directly into that cylinder and causes issues. Do a compression test to find out 100%.
Old Nov 28, 2007 | 03:49 PM
lostin90s's Avatar
lostin90s
bad news I have bought 5 trucks to fix all with # 8 bad all between 110000 and 130000.
Check compresion . Post back
Old Nov 29, 2007 | 11:12 AM
ford150man's Avatar
ford150man
Did compression check and #8 cylinder read approximately 45 lbs , but when you step on the gas it would go to 75lbs. Does this mean anything? The #7 cylinder read approximately 125 lbs. Thanks!
Old Nov 29, 2007 | 11:47 AM
danr1's Avatar
danr1
How are you doing this compression test? All plugs removed, do not give it gas. Testing one cylinder at a time letting the piston hit on the compression stroke 3 or 4 times to build compression. Record the value for each cylinder.
On the cylinder with the low reading, put in 3-4 tablespoons full of new, clean oil in the plug hole. Run the test again, if the compression comes way up it's likely to just be really bad rings. If the compression doesn't come up at all, or it only comes up very little then you have a severe mechanical failure.
Old Dec 3, 2007 | 06:13 PM
ford150man's Avatar
ford150man
Did a scan for codes , but don't think the codes have anything to do with bad cylinder. Codes are 636-transmission oil temp. higher or lower than expected. 114-Air charge temperature sensor higher or lower than expected voltage. 327-EGR closed valve voltage lower than expected. 332-Insufficient EGR flow detected. And the last one was 334-EGR closed valve voltage high. Thanks for your help.
Old Dec 4, 2007 | 07:10 AM
frankyford's Avatar
frankyford
To me it sounds like it valve seal has gone bad and it seaping into the exhaust port of your head and coating your plug. Thus the blue smoke coming out your tailpipe. Hope this helps, I had an 87 Cougar that did this
Old Dec 4, 2007 | 09:09 AM
ford150man's Avatar
ford150man
I'm no mechanic. Does this mean the motor is junk? Does this mean the cylinder isn't bad? Thanks for you help.
Old Dec 4, 2007 | 09:17 AM
danr1's Avatar
danr1
What did the compression test method in post "11 tell ya about its condition?
