Sponsored by: Auxito
torsion bar replacement
Old Dec 4, 2007 | 12:23 AM
ididntdoit99's Avatar
ididntdoit99
I've seen that they made different "Grade" torsion bars some being stiffer than other. Would changing the torsion bars on my 97 f-150 ext cab 4x4 to a stiffer grade provide any more lift in addition to re indexing them?
Old Dec 4, 2007 | 04:46 PM
tim.moman's Avatar
tim.moman
Lots of discussion about this over on the f150 forum. fair amount here as well. The main problem is that ford will not give the spring rates of the bars. So... It is difficult to impossible to know what is stiffer and by how much. Lifting should be viewed seperately from carrying weight. (spring rate required). To adjust the hieght is a function of indexing the bars. If adding or removing weight, then the rate of the bar should be changed.
Caution changing axle angle has some side effects.
Old Dec 4, 2007 | 06:28 PM
ididntdoit99
yeah i think it was on a chevy forum where is saw that they were rated with different letters. So the ford bars don't say on them what they are rated for?
Yes, but in theory if you could get a stiffer spring and use the key to index it, it would be a higher lift than the stock bar indexed the same, right?
Old Dec 5, 2007 | 11:13 AM
tim.moman's Avatar
tim.moman
Yes they do chart the spring rates of their torsion bars. I also heard rumors from the desert that they hold up better, and will bolt into the F150??? The down side is we can't get the current rates as a starting point. Ford will only look up what is coded on the vehicle and offer a replacement. I have a push bar and wanting to add a winch, so looked into stepping up for the added weight.
Your theory is sound as stated, but unless you are at the edge of adjustment and need that very small tweek, The increased spring rate if not needed will be more detrimental than the benefit. An aftermarket indexed key will gain the adjustment you might need. Strangley, I had to go a key just to get the axles level. But this truck has seen some pounding, so the bars may be going. The rear leafs were drooped about 2 inches when I changed them.
Old Dec 5, 2007 | 04:10 PM
xtrford's Avatar
xtrford
Might want to look at the 7700 F150 torsion bars, I heard they are stronger than a standard F150.
Old Dec 5, 2007 | 04:22 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
They should be, because they are rated to carry a snow plow...no other half ton is factory rated for a snow plow
Old Dec 5, 2007 | 05:09 PM
tim.moman's Avatar
tim.moman
7700 bars are longer and will not fit.
Old Dec 5, 2007 | 06:22 PM
BURNSTOUGHFORD
really, they moved the mount farther back on the frame rail? weird
Old Dec 5, 2007 | 07:45 PM
tim.moman's Avatar
tim.moman
yep thats what i understand anyway. the idea has come up before here and on the f150 forum
AhoyMatey
1997 - 2003 F150
Apr 11, 2014 06:04 PM
shootr19
1997 - 2003 F150
Feb 23, 2012 09:08 PM
kup2you
1997 - 2003 F150
Aug 12, 2011 07:37 PM
pursugr
Offroad & 4x4
Aug 4, 2007 06:52 PM
Merculous
1997 - 2003 F150
Mar 24, 2005 09:41 PM
