Offroad & 4x4
slight driveshaft problem....
Old Dec 3, 2007 | 12:13 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
well, i just finished my truck but my drivline angle seems to be a bit steep....what do you guys think...
what should i do to fix my problem.....its pretty smooth till about 80mph....then i get a weird vibration....
Old Dec 3, 2007 | 12:24 PM
Beechkid's Avatar
Beechkid
I have two suggestions...
1. Find a good driveline shop and inquire about other types of u-joints, check the balance of the shaft or possibly a mid-mount bearing to maintain the shaft position.
2. Go to a 2 piece unit.
Old Dec 3, 2007 | 12:27 PM
2000silverbullet's Avatar
2000silverbullet
Bwahahaha!! Looks like it would be safe to me <note sarcasm>...
On a lighter note, sweet blocks and neon lights!!!
Old Dec 3, 2007 | 12:29 PM
2000silverbullet
sorry for the double post, stupid internet...
Old Dec 3, 2007 | 12:30 PM
Beechkid's Avatar
Beechkid
Old Dec 3, 2007 | 01:23 PM
quadzjr's Avatar
quadzjr
so this is not how im supposed to set it up.....
lift blocks are the only way to lift a truck correctly....
Old Dec 3, 2007 | 03:40 PM
quadzjr's Avatar
quadzjr
i wish they had a thornbird tire tall enough....i wish they came in a 54.....those are the baddest a$$ tire ever invented!!!!
Old Dec 3, 2007 | 03:57 PM
1979f350inline6's Avatar
1979f350inline6
did you guys see the fuel filter on the axle breather hose???
Old Dec 3, 2007 | 05:54 PM
zpmps2's Avatar
zpmps2
Asking somebody >>> "That kinda vibration is normal over 80 RIGHT, if not im in a hole lot of ****!"
Old Dec 3, 2007 | 05:56 PM
zpmps2's Avatar
zpmps2
Thats so it can breath COOL, Filtered air, otherwise, she'd bLOW!
Old Dec 3, 2007 | 06:00 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
I don't see a problem......just add a turbo_dynamics semi-harmonic gyroscopic double pin stabilizer - they are rated to 140 mph @ sea level, 130 @10,000 feet (which is where you'll be at when it takes off).
Old Dec 3, 2007 | 06:16 PM
2000silverbullet
You can actually use a throttle body spacer to help with that shudder...
Old Dec 3, 2007 | 07:15 PM
quadzjr's Avatar
quadzjr
i was told that would make my truck go faster....cleaner air in the diff.....
Old Dec 3, 2007 | 07:16 PM
quadzjr's Avatar
quadzjr
thanks....ill give it a shot...
Old Dec 3, 2007 | 07:50 PM
STGFordCrazy04's Avatar
STGFordCrazy04
My suggestion is weld a gear on the end of your xcase yoke and another on your pinion yoke and connect it with a bicycle chain. That way you can change the gear reduction by swapping yokes instead of changing gears in the axles or running a doubler. I just got off the phone with a big wig at Interco and he said if we could get enough people interested in a 54" Thornbird he'd mold them up. They will only be available in 15" rim so they will be easy to bolt up to D28 TTB and Ford 7.5 axles
