DP-Tuner Question
Old Dec 3, 2007 | 07:16 AM
pullinair's Avatar
pullinair
DP-Tuner Question
Why is it that when I remove the F-5 switcher (when the truck is shut off), the truck will not run without it. I thought If you remove the Switcher the truck runs strictly off the PCM. Mine is not, it will barely rev up with the F-5 switch off and engine stalls if you try pulling out. Never did this before. If you put the switch back on, the truck will run in every program. Like there is nothing wrong.
Tim
Old Dec 3, 2007 | 07:32 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Tim
When you pull the switch off it goes into anti theft mode. Need the switch to run. Do you have the stock tune in it?
Old Dec 3, 2007 | 07:38 AM
mueckster's Avatar
mueckster
My understanding is that the F5 switch can be removed as a security measure to keep the truck from starting. The piggyback chip would then have to be removed from the PCM to be able to start and run without it. I have only used the buttons on the switch to go from the tunes to "no start".
Old Dec 3, 2007 | 07:51 AM
Izzy351's Avatar
Izzy351
hhmmm... Mine doesn't do that. It defaults to stock when removed. I have to physically activate "0"/No-Start, shut down the truck, then remove the F5.
Old Dec 3, 2007 | 07:55 AM
pullinair's Avatar
pullinair
Originally Posted by miller_feed
Tim
Called Diane and she said the same thing. I just had no start added recently in pos 0. Never thought about it defaulting to no-start, unlike the old chip which defaulted to stock, when i pulled the switch.. BTW, apparently the no start that i have lets the thief start the truck but it immediately dies if he gives it gas. This is what was happening to me. Maybe Jody did this to prevent thiefs from buring up starters. I all can say is that it works.
thanks for the replies.
Tim.
Old Dec 3, 2007 | 08:20 AM
miller_feed
Yeah Tim, we are lucky we have people like them still helping us 7.3 owners.
Only wish I had the new switch for the gauge cluster on the piller. But then I would have to get the 4 cluster.
Old Dec 3, 2007 | 05:18 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Wouldn't do much good if he could just idle down the road!
Old Dec 3, 2007 | 06:02 PM
nhill2090's Avatar
nhill2090
he probably wouldn't get too far just idling
