tire size question
Old Dec 2, 2007 | 03:15 PM
DND58's Avatar
DND58
tire size question
Hey Guys, I have an 02, 350, 7.3L, 4x4 with new LTX/MS stock size 265/75/16E's. I also have an 88, 250 with worn out 265/75/16D's. Stock size on the 88 was 235/85/16E. While looking for tires, the fact that the 1988 tire size is not stock seems to concern tire dealers. Maybe the "D" rating, not sure. I've noticed no problems running the 265/75/16D tire.
Anyway, I was thinking of putting on the same size 265/75/16E on the 250, but more aggressive than the LTX. This truck dosen't see any real weight/towing anymore, but this way the tires would be compatible with the 350 if I wanted something more aggressive in the future. What do you think?
DND58
Old Dec 2, 2007 | 03:19 PM
powrstrkn''s Avatar
powrstrkn'
I'd go for it as long as you don't plan on hauling heavy. Always follow tire manf. recomendations
Old Dec 2, 2007 | 04:31 PM
clintbonnie's Avatar
clintbonnie
As long as they are all E rated, you should have no problem. Your speedo might be off with a different tire size.
Old Dec 2, 2007 | 06:15 PM
lee231's Avatar
lee231
The 'E' rating is more plys and is for hauling heavier loads. We had a tire company put 'C' rated tires on out shop truck, it's wasn't long before the tires had blisters on the side of the tire because the truck(van) was suppose to have 'E' rated. We're lucky not to have a blowout on the van being it was fully loaded most of the time with electrical equipment. Lee
Old Dec 2, 2007 | 07:23 PM
Mr. Bob's Avatar
Mr. Bob
well, the 235/85R16 is a 31.7x9.5", the 265/75R16 is a 31.8x10.5"... so they are the same height tire, just the 265 is 30mm wider than the 235.... so 1" wider....
Cstjlw
1997 - 2003 F150
Mar 1, 2015 06:48 AM
IslandBlueV10
Nov 8, 2011 12:19 PM
Brew Camper
May 11, 2007 02:40 PM
folsomf250
1997 - 2003 F150
Apr 26, 2004 08:24 AM
neato5oh
Feb 7, 2003 04:34 PM
