98 e40d transmission problem
Old Dec 2, 2007 | 11:24 AM
timtheartist's Avatar
timtheartist
I am having a problem with my transmission. It operates fine in 1st or 2nd, but when it shifts into third, there is a chugging/tendency to shift into od prematurely. The problem does not appear when I am towing. I just had the fluid changed, but the problem is still there. It has gotten to the point where I will occassionally turn off od just to avoid the problem.
5.4l engine/90k miles on trans, fluid changed at 80k
Old Dec 5, 2007 | 11:22 AM
blue beast's Avatar
blue beast
http://www.lincolnsonline.com/tech/00080.html Abit long for a fluid change. I pull
out a half quart to quart every motor oil change with a mity vac hand pump and a
hose as long as the dip stick. with the price of trannies the extra time is worth it if
it only lasts an extra 5000 miles even. The biggest advantage to it is the reup of the
additive package, You could use some of this stuff in lieu of the half quart every now
and then and it may help your current problemo!!http://www.transmissionpartsusa.com/...-000063010.htm
400m
1983 - 2012 Ranger & B-Series
Apr 16, 2009 09:49 AM
sharp94xlt
24
Oct 13, 2008 04:22 PM
Joebuddens
Mar 29, 2007 09:28 AM
92 Red F150
Jun 3, 2005 09:46 PM
raytasch
Jul 20, 2004 11:13 AM
