General Automotive Discussion
Trikes
Old Dec 1, 2007 | 06:34 PM
rustyoldford's Avatar
rustyoldford
Trikes
General automotive---hmmmmmm- seems like the closest catagory, my other choice would be bodywork
Anybody got any good ideas (links to another site) about slicing off the front of a front drive ford car, and welding a bike frame on the front!!!!!
A vw trike is out of the question-yuckkkkkkk
I mean is there enough substantial unibody there to weld to, or do you think this is an unbolt and fabricate everything job.
Old Dec 1, 2007 | 10:17 PM
Dean88's Avatar
Dean88
Anything is possible with a little time and money. I saw at a bike show once a bike with a 460 on it.
Old Dec 2, 2007 | 07:09 AM
rustyoldford
Well I've seen pics of a 24 cylinder trike (had 12 exhaust pipes on a side anyhow) not sure I'd want to drive it
Old Dec 2, 2007 | 07:15 AM
Greywolf's Avatar
Greywolf
Uh...
Front drive, cut off the front, bike front end....
You DID want an engine in this thing somewhere, didn't you?????
I'm puzzled.
Then again - there is always the Stallion:
Old Dec 2, 2007 | 07:24 AM
rustyoldford
Engine? yep, probably leave the 4 or 6 cylinder on the transaxle, just throw away the rest of the car. Need a project for my spare time
anybody interested the BTW site (brothers of the third wheel) has a large photo section
Old Dec 2, 2007 | 07:26 AM
Greywolf's Avatar
Greywolf
The above pic is from a SEMA auto show, "Stallion" is a ford powered trike,
Old Dec 2, 2007 | 08:01 AM
rustyoldford
Nope I'm not gonna do body quite that fancy, may as well put a roof on it, and drive it all winter
How'd you get the picture in here , best I could figure out was a 60x40 avatar
Old Dec 2, 2007 | 08:05 AM
Greywolf's Avatar
Greywolf
I copied the link from the source, and used the "INSERT IMAGE" thing in the go advanced reply option. One tip: When you use that, delete the HTTP: that is in the blank for the image address when you insert yours. You'll see what I mean.
Otherwise there will be two of them in the image address.
Old Dec 2, 2007 | 08:24 AM
trike1946's Avatar
trike1946
After a certain point the "trike" becomes a 3 wheel car. A bike is a bike and a car is a car even if it only has 3 wheels. Some bikes have fairing, but they do not have "bodies". Part of the bike thing is being open and in the wind. I ride until my hands and my helmet get froozen. Then I put it away until the spring. Some ride all year. If it rains you get wet. To me if you put a roof on it you go from bike to car. If you want a project bike, build one. You can use an old flat head Ford engine to be different.
If you want easier you can take the VW you don't like and trash the engine. There are companies that make adapters to hook a harley engine on the back of the trans axle. But they end up long and wide.
How about converting a street bike to a trike.
Old Dec 2, 2007 | 09:09 AM
rustyoldford
put the harley engine on the vw axle? no not me, and I think I'll skip the flathead also
4 or v6 ok, and theres enough of them available, just put the passenger seat fiberglass body over the engine, driver in front, springer in front, and hopefully the front end will stay on the ground at highway speed
Old Dec 2, 2007 | 01:19 PM
dono's Avatar
dono
Gone but not forgotten.
Why yuckkk? A modified Bug engine is capable of more horsepower than a trike will need.
Could be done by a skilled craftsman (and a plumber for the radiator).
Old Dec 2, 2007 | 07:26 PM
rustyoldford
just never liked vw,
why put all that money in a bug engine, still sounds like a baby farting
i certainly think a stock front wheel drive would power a trike really well based on sweeties buick v6
radiator, yes, need to put that somewhere, and sheild the passenger area from the radiant heat, at least it can be plumbed anywhere, no worries about ducting adequite air to fins
bending the 1/8" wall tubing is a little intimidateing though
Old Dec 3, 2007 | 12:18 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
A guy I know over at another website ( www.3wheelerworld.com ) made a 3-wheeled car (two of them actually). He chopped off everything behind the front seats and fabbed up a 3-wheelers front forks and tire.
Old Dec 3, 2007 | 08:32 AM
Dean88's Avatar
Dean88
Here's an idea.
http://www.bikemenu.com/Jesse%20Jame...%20Garage.html
Old Dec 3, 2007 | 02:34 PM
FLgargoyle's Avatar
FLgargoyle
You should drive a trike before you try it- esp. a single front wheel. I test drove a VW one once that I wanted to buy- dangerous! The front is too light for the weight and power in the rear, so you have to back off the throttle completely to go around a curve. Roll the throttle on, and you straighten out- whether you want to or not. I did a lot of research on this, and the best configuration is 2 front wheels w/ front wheel drive, and a single rear wheel. They handle much better.
