air induction kits
Old Nov 4, 2001 | 08:18 PM
tmcalavy's Avatar
tmcalavy
air induction kits
Hey Phat,
what is that right behind the filter? the coffee can you mentioned? or is it part of the expedition filter set up?
Old Nov 5, 2001 | 07:19 AM
TallPaul's Avatar
TallPaul
air induction kits
I would think the stock intake tubes with their accordian folds must really mess up air intake and that just changing those to smooth hose would help alot. Maybe I will try this next.
What about getting a larger airbox? I saw a filter for an E350 van that looked to be about 10 by 10 inches. Or how about two airboxes so each set of three cylinders draws from a different box?
Only mods to my intake are a K&N filter, trimming the excess off both ends of the snorkel as they were bowing in and constricting flow, and pulling the grill flap over to a couple inches into the grill to catch come incoming air directing it to the snorkel area.
INLINE SIX POWER!
https://www.ford-trucks.com/dcforum/User_files/TallPaul/3bd090f91fd9e18d.jpg
300 Cubic Inches of Low RPM Truck Torque!
Old Nov 5, 2001 | 03:35 PM
phatpharm85's Avatar
phatpharm85
air induction kits
Hey Phat,
the coffe can is inside the end of the filter and the flex tubing to give somethin solid in there to tighten the hoseclamps on other wise you would just chrush the filter end and flex tube because they are soft rubber. i was going to try and incorperate parts from the expedtion set up but i didnt want to cut to much or use to much cause i wasnt sure what my dad was gonna do with them
Old Nov 5, 2001 | 03:38 PM
phatpharm85
air induction kits
INLINE SIX POWER!
actually one of the first things i thought up was going with two smaller k&n say from like a quad or some other small engine and then two tubes right off the intake to the filters but i think the way i did it will flow better with the bigger filter and make better use of the air blowing in from the stock snorkal or wut ever you want to call it
Old Nov 5, 2001 | 11:33 PM
Nod's Avatar
Nod
air induction kits
AmericanIron460
18
Oct 19, 2015 01:25 PM
Ssrkid86
Sep 26, 2015 01:58 AM
trucker01
16
May 10, 2014 09:23 PM
OldWoodsDiesel
Dec 21, 2012 08:42 AM
edouble33
2009 - 2014 F150
Jul 23, 2010 03:21 PM
