T-case
Old Dec 1, 2007 | 03:44 AM
factory594x4's Avatar
factory594x4
Question T-case
What model T-case is used in the 59' 4x4?
Old Dec 1, 2007 | 10:02 AM
75F350's Avatar
75F350
59 to 64 F100's typically used a Dana 24 transfer case.
Easies way to verify, is to climb under and find the tag. These ID tags and markings are very durable and can will still be visable.
Other ways would be to determine whether or no the shift pattern has a neutral. The Dana 21 was simply a 4wd / 2wd slection, and low range was not an option.
You can narrow down possibilities by just verifying some of these things that set each case apart.
Old Dec 1, 2007 | 01:00 PM
factory594x4
F-250 hi/lo has neutral
Old Dec 1, 2007 | 01:02 PM
75F350's Avatar
75F350
That eliminates the Dana 21. Looking like a Dana 24.
Is this the original case, or has someone installed a newer one?
Old Dec 1, 2007 | 01:05 PM
factory594x4
it is the Original
Old Dec 1, 2007 | 01:34 PM
75F350's Avatar
75F350
Should be the 24.
DesertSmoker
Sep 5, 2018 04:48 AM
Amphihauler
Oct 15, 2016 05:10 PM
2kcrewcab
Apr 8, 2008 03:15 PM
86BroncoGuy
Mar 9, 2008 09:58 AM
BigJake86
Aug 6, 2002 05:18 AM
