44" tires should fit on a stock bronco with enough sledge hammer actions and removing several pieces of sheet metal.. and no a d44 with break in fear as your trying to put the 44" boggers on.
don't you guys know the 44 in d44 means you can run 44s?
idiots..
That's right. That is just the Working Load Limit !
So really at worst conditions the D44 will easily handle 44" tires, but 54s would work to if you take it easy!
Hey, I know I haven't been on in a couple weeks, but when did all the good tech stuff start. I bet after welding the coil springs together, the heat would make them extra progressive.
