Front End Squeaking
Old Nov 30, 2007 | 09:28 PM
BroncoEx's Avatar
BroncoEx
Front End Squeaking
Hello All..........
Wife's 2005 EB Explorer is starting to squeak alot going over bumps.
When I climb under, it looks like a steering Stabilizer bar??? that runs side to side. It is held in place by going through 2 rubber bushings. What should I lubricate these with? Grease? Silicone? Oil? WD-40?
All help is appreciated.
tim Z
Old Dec 1, 2007 | 09:53 AM
steve(ill)'s Avatar
steve(ill)
i put wd40 on the kids Mustang a couple years ago and it lasted 2 weeks. Finally took the rubber sleeve off, coated with antisieze and reinstalled-- 2 years later, no squeek.
Old Dec 1, 2007 | 12:01 PM
rrgone's Avatar
rrgone
It's the rubber sway bar bushings creaking when the front wheels lift going over a bump. You can lube them up or replace them with poly bushings. Google for 'explorer sway bar bushing' and you'll find lots of sources for new bushings.
Old Dec 5, 2007 | 09:53 AM
4.0 Beast's Avatar
4.0 Beast
is there anywhere that shows a how-to on replacing them?
