radio interference
Old Nov 30, 2007 | 08:01 PM
taki0187's Avatar
taki0187
radio interference
I have a 99 mountaineer I seem to be getting am radio interference I checked all the grounds and alternator as per the service manual anyone else with this problem,fm, cd player work fine thanks in advance
Old Dec 2, 2007 | 09:05 AM
marragtop's Avatar
marragtop
Does the interference vary with the engine RPMs? If so, what kind of ignition wires are on it?
Old Dec 2, 2007 | 03:06 PM
Rick55's Avatar
Rick55
I have the same issue - '99 Explorer with 137K, still has the original wires on it. AM reception is very poor with lots of static, but if I turn the engine off it is much better.
Do you think replacing the ignition wires will help? I figure it's time to change them anyway.
Old Dec 2, 2007 | 04:22 PM
Crazed1122's Avatar
Crazed1122
i have the same problems on and off, i have a different Radio than the stock one, so i know its not the radio. Does it get worse as you accelerate becasue mine makes a louder noise and changes pitch as i accelerate.
95 Explorer
Old Dec 2, 2007 | 07:27 PM
ltng7679's Avatar
ltng7679
I had some limited luck on my 98 with playing with the antenna plug that can be accessed by dropping the glovebox down. The connection is just behind the glovebox.
Old Dec 2, 2007 | 10:23 PM
Bear River's Avatar
Bear River
Former ******
Sounds to me like you are getting electromagnetic interference from the ignition system. Time to do a tune up and replace the plugs and wires. Use only Motorcraft or Autolite parts, it matters.
PapaBearYuma
Jan 11, 2017 08:14 PM
IDI Diesel
Apr 12, 2016 08:35 AM
tjdad62
May 20, 2014 09:00 PM
Dave145
Aug 14, 2013 09:36 PM
muckypaws
1978 - 1996 Big Bronco
Jul 4, 2006 09:57 AM
