Sponsored by: Real Truck
Radio Interference
Old Apr 11, 2016 | 12:09 PM
IDI Diesel's Avatar
IDI Diesel
Radio Interference
Tricky problem that started for me this weekend. I installed a backrack and two LED light pods on my CCLB 350 and when I turn the lights on while playing the radio it gets staticy. Can anybody explain why this would happen? I have the lights on my upfitter switch #2 and the other switches have accessories but do not cause the radio static.
Old Apr 11, 2016 | 01:28 PM
Firekite's Avatar
Firekite
Are you powering directly off the upfitter switch, or only powering a relay with the switch?
Old Apr 11, 2016 | 01:49 PM
IDI Diesel's Avatar
IDI Diesel
Powering directly from the upfitter switch.
Old Apr 11, 2016 | 03:25 PM
Firekite's Avatar
Firekite
Yeah, you probably want to fix that, then. It should only take milliamps worth of current to trigger a relay. Running them right off the switch will draw a lot more current through it. As long as the switch is rated for it, it's not dangerous, but it has other undesirable effects.
Old Apr 11, 2016 | 03:42 PM
IDI Diesel's Avatar
IDI Diesel
The switch is rated for 15A i believe andthe lights are only 5A. Why would ford rate a switch for that amperage yet let it cause interference?
Old Apr 11, 2016 | 03:59 PM
Firekite's Avatar
Firekite
Because RFI is everywhere and they didn't feel like providing the kind of shielding and filtering required for your application?
Old Apr 11, 2016 | 04:07 PM
wrvond's Avatar
wrvond
The switch doesn't cause interference. It's the LED's. They are also known for interfering with TPMS operation.
Old Apr 11, 2016 | 04:12 PM
IDI Diesel's Avatar
IDI Diesel
Wow never heard of LEDs causing RFI.
Old Apr 11, 2016 | 04:17 PM
wrvond's Avatar
wrvond
A quick search of the forum returned seven threads other than yours on this. Here's an example: https://www.ford-trucks.com/forums/1...-pressure.html
Old Apr 11, 2016 | 04:29 PM
RightWingNutJob's Avatar
RightWingNutJob
Upfitter switches already drive Ford Relays. No need to use a relay to drive another relay. It won't help your noise problem anyway.
Like other posters said, the LED lights are the source of your noise. Depending on the design of the LED driver circuitry, it could either be radiating Radio Frequency Interference (RFI) or conducting electrical noise back through the truck's electrical system and you're hearing it through the radio.
Old Apr 11, 2016 | 04:38 PM
IDI Diesel's Avatar
IDI Diesel
Sort of sucks that they do it but I guess Im stuck with it
Old Apr 12, 2016 | 07:43 AM
sxrfun's Avatar
sxrfun
Yep WHS^^^^^ Some brands of LED's will do this....Could be the cheaper makes that do this who knows....I have Philips LED's in my headlights, fog lights, tail lights and marker lights with no problems with radio interference.
Old Apr 12, 2016 | 07:45 AM
IDI Diesel's Avatar
IDI Diesel
I'll just deal with turning the radio when I use them or hook up my ipod
Old Apr 12, 2016 | 08:35 AM
Crispy71's Avatar
Crispy71
You could look into an RFI filter. There are several inexpensive ones on Amazon. Also Popular Mechanics has a reasonable article on it as well. Curing Radio Noise
throwdown
Apr 14, 2010 04:51 PM
e-manfive
Oct 16, 2004 10:42 AM
Shake-N-Bake
Electrical Systems/Wiring
Oct 23, 2003 11:31 PM
