Another oil leak question.......
Old Nov 30, 2007 | 10:55 AM
Riata_Ag's Avatar
Riata_Ag
To save me hours of searching, I was hoping someone might be able to provide me with a list of common problem areas for leaks that deposit oil into the valley. Beginning with the "most common" first.
I have another leak, can't really tell where its coming from yet, but its NOT leaking down onto the ground YET. Wet under the fuel filter and puddled under the turbo.
I know this type of question has been asked 1000 times or more on this forum, and a common suggestion is to clean the area with degreaser and run engine and look for leaks. BUT, I feel like a list of problem areas and knowing the areas that leak more often than others will help me to look in the right places AFTER cleaning.
Thanks in advance,
ra
Old Nov 30, 2007 | 12:55 PM
plowhand's Avatar
plowhand
Playing in the Dirt
First question; is it oil or fuel? There is a long list for each and this will save some typing.
Old Nov 30, 2007 | 01:46 PM
Riata_Ag's Avatar
Riata_Ag
Plowhand,
I am glad you asked that question as I posted oil leak. Last week I was installing my new Stancor GP relay and saw the puddle down there, in the dim light it looked like oil.
BUT, before I answered your question I went and stuck my finger down there to make sure.
My final answer is: it is FUEL.
There is a puddle under the filter housing and under the turbo. Not sure how much is leaking or where its going, but there is not anything leaking onto the driveway, YET.
I don't think it matters but the engine has 119K miles on it. About 6 months before I bought it, at 91K miles, the previous owner had the fuel filter canister replaced at the dealer because it has some tiny holes in the bottom from rust. Perhaps I can eliminate that one.
Thanks
ra
Old Nov 30, 2007 | 01:56 PM
250turbo's Avatar
250turbo
check weep hole in fuel pump
Old Nov 30, 2007 | 02:34 PM
plowhand's Avatar
plowhand
Playing in the Dirt
O.K. fuel it is. Front and middle of the engine valley(under fuel filter) (remember it will drain to the back, sloped engine) Fuel filter housing (not likely with a new one), Water drain valve, filter restriction sensor, FPR, fuel hoses, high pressure fuel return lines from each head to the FPR (usually not) fittings on high pressure lines at head(this would leak at the very front of the valley) and at FPR.
Rear of valley. As stated above fuel pump, bango fitting, high pressure (steel) fuel line fittings going into head. I think thats everything, but someone will correct me if I missed something.
Old Nov 30, 2007 | 02:48 PM
Riata_Ag's Avatar
Riata_Ag
this is probably a stupid question but
where exactly is the weep home on the fuel pump, it seems to me that the fuel pump is kinda hard to see just for observation........
Its pretty dry on the front of the engine, but puddled under the fuel filter and under the turbo.
After checking the weep hole, if its not leaking I guess I'll remove the fuel filter canister and replace all of the fuel hoses and clamps..........how does that sound......
Old Nov 30, 2007 | 02:57 PM
trike1946's Avatar
trike1946
It is at the bottom of the pump on a small flat section that runs top to bottom, maybe 3/16" wide. If I remember right it is on the passenger side. The flat section takes a turn at the bottom, towards the center, and that is where the small hole (1/16") is. You probably need a mirror.
Old Nov 30, 2007 | 03:17 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
[QUOTE=Riata_Ag]this is probably a stupid question but
QUOTE]
Check this pic.
Old Nov 30, 2007 | 03:40 PM
Riata_Ag's Avatar
Riata_Ag
There are 2 weep holes?
Indicated by the red arrows...........
Old Nov 30, 2007 | 03:51 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Bottom arrow is the weep hole. Top arrow is the crimp on the pump body. Usually have to use an inspection mirror to see the weep hole while the pump is on the truck.
Old Nov 30, 2007 | 05:53 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Ditto what plowhand said.
Old Dec 1, 2007 | 08:29 AM
Riata_Ag's Avatar
Riata_Ag
Thanks for the pics........
looks like I may be spending my Christmas break working on the ol truck
What the best place to get those rubber fuel hoses that are rated for diesel fuel?
thanks
Old Dec 1, 2007 | 09:16 AM
dinikin's Avatar
dinikin
Above are right, the weep hole is shown by the bottom arrow.
When I posted the pic, my idea was to show 2 areas where fuel was leaking on my pump.
If you look closely you could see how diesel washed out clean a certain area on the pump, kinda like leaving a foot step in the snow.
[QUOTE=RÖENTGEEP]
QUOTE]
Check this pic.
Old Dec 1, 2007 | 05:17 PM
trike1946's Avatar
trike1946
I bought mine from Ford. So I guess International has them too. Maybe NAPA, but never tried there. They have the pumps so they ought to have the hoses.
Doc
6.4L Power Stroke Diesel
17
Dec 8, 2013 02:47 PM
LSO1123
Mar 20, 2013 10:58 PM
northwindone
Modular V10 (6.8l)
45
Feb 14, 2013 08:39 AM
disneyd
Apr 14, 2011 11:50 AM
89nolaf250
45
Dec 8, 2009 01:59 PM
