2wd/4wd header?
Old Mar 16, 2008 | 12:45 AM
1982bluef150's Avatar
1982bluef150
thanks for the welcome and the info guys... i was just at a garage today and they said $250 to put it on there im positive i can do it myself... its just the only torch i had is a propane one and i dont wanna get severely stuck ya kno
one thing i was curious about was the vacume lines and the metal tube that come out of my manifold... i was wondering what i should do... just block them off? or is there a special way? i think the metal tube is the egr and its pretty rusted into there... so i guess id take off the square thing it goes into on my carb and make a blcokoff plate
and the other thing i was worried about was the gaskets and my starter the starter is easy enough with a heat sheild wrap... but the gasket i guess ill just double up and glue together considering i have a tube of the copper rtv in my garage
then i was thinking the smaller the exhaust pipe i run the better my fuel economy is going to be.... haha whats your thoughts on this guys? i was kinda thinking to run a dual 2.5 inch pipe at least a foot back from the collectors then y them both into a single 2.5....but for some reason that sounds like it shouldnt work well to me... and id like to stay away from 3 inch pipe... not sure why but it just seems a lil big
thanks for the help and i guess ill order my stuff either tomorrow or monday from summit
Old Mar 16, 2008 | 12:25 PM
optikal illushun's Avatar
optikal illushun
what ya need to torch?
Old Mar 17, 2008 | 01:35 AM
1982bluef150
the manifold bolts
Old Mar 17, 2008 | 07:25 AM
Doublebass73's Avatar
Doublebass73
Has anyone run headers with a true dual setup? I'm thinking 2" pipes with an H-pipe and tailpipes coming out the back might sound nice.
Old Mar 17, 2008 | 07:31 AM
1982bluef150
true dual doesnt have a cross pipe right? and i heard 2 and 1/4 works best
Old Mar 17, 2008 | 01:33 PM
fmc400's Avatar
fmc400
MSEE
My plan is to do true dual 2 1/4's. I've heard good things about it.
Old Mar 17, 2008 | 01:43 PM
Pkupman82's Avatar
Pkupman82
I am going with single 3" on mine... trying something new.
Old Mar 17, 2008 | 05:42 PM
1982bluef150
id like true duals... but i figure if im doing it right might as well put a cat on it and run single cuz its easier and cheaper than 2 cats
Old Mar 18, 2008 | 09:52 AM
Pkupman82's Avatar
Pkupman82
That's for sure cats aren't cheap, the good flowing ones anyway!
Old Mar 19, 2008 | 05:42 AM
1982bluef150
well i called up the local truck scrapper on monday and told them to look for some after market intakes/headers.... i figure why drop like 400 on stuff when i can cheap out and do it for 250- 300 .... now i gotta worry about the stuff bein warped hahaha
Old Mar 22, 2008 | 02:11 PM
Econoline 4x4's Avatar
Econoline 4x4
Part number
What is the part number for those Hedman Headers { 4.9l l6 } I would like to check them out and wondering if they would fit in an Econoline?
Old Mar 23, 2008 | 02:42 AM
1982bluef150
HED-89300
thats the summit part number anyway
Old Mar 23, 2008 | 02:57 AM
  #28
1982bluef150
Originally Posted by hoxiii
When running headers something to check is the collector length. The lower the RPM of the motor, the longer of a collector it will benefit from. Most headers out there have a collector that works best in the 8,000 rpm range (not kidding).
For something like a 300 a collector length of 24"+ (based on packaging) would be alot better than the 3" looking one in the picture on summit racing
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HED%2D89300&N=700 +4294839039+4294908331+4294918680+4294908312+42949 25023+4294840102+115&autoview=sku
all the extension really needs to be is a piece of pipe off of the collector with a mtaching diameter. heck, a glasspack attached straight to the collector will act like a collector extension if the diameters match. the collector "ends" when the exhaust sees it's first major change in pressure (like stepping down from 2.5 to 2.25 or even stepping UP from 2.5 to 3)
Justin
is he right?? i really want the right sized exhuast on my truck.... but everyone has a different thing to say
Old Mar 25, 2008 | 09:55 AM
  #29
waynaferd's Avatar
waynaferd
I got a set of Hedman's for my 84 4x 4-speed, then used them on my 75 2wd auto. They fit both vehicles fine. One thing you'll want is a heat shield for the starter ( I used a coffee can), or you'll get good at replacing them.
Nathan Plemons
May 12, 2015 05:15 PM
FordPower92
Mar 1, 2015 06:26 PM
Big Sky Highboy
22
Mar 1, 2015 05:30 PM
GI8U2racing
Apr 29, 2010 03:12 PM
BarnieTrk
Exhaust Systems
Mar 24, 2010 05:29 PM
