few carb questions...
Old Nov 29, 2007 | 05:41 PM
Kuskoal's Avatar
Kuskoal
hi there, i have a couple questions about carbs, emissions and tuning tips.
1: would it be a good idea to put a 600 CFM holley 4160 on a 1981 302? (sadly i have the bad year of required emissions)
2: would you think it would pass emissions with the holley on it?
3: This one is just general knowledge: how can you tune a carburator right? i hear that a out-of-tune carb results in less mileage, spark plug fouling and other problems.
Thanks for your help
Old Nov 30, 2007 | 05:33 AM
LxMan1's Avatar
LxMan1
1] Where do you live? What all is involved in the emissions testing?
2] A 600 will work fine on a 302.
3] Basic tuning is done by reading the spark plugs to get them a light brownish color. White is too lean, black is too rich. You really just have to try it and see how it does before changing jets and stuff. I have had them run fine right out of the box.
Old Nov 30, 2007 | 05:58 PM
Kuskoal's Avatar
Kuskoal
i live in reno nevada, i know i need the cat/a.i.r. stuff and my emissions requirements for a 1981 truck is 1.2% i believe.
Old Nov 30, 2007 | 07:05 PM
LxMan1's Avatar
LxMan1
As long as there is not a visual check for the original carb, it should be ok.
Old Dec 3, 2007 | 07:51 AM
Danger_Dave's Avatar
Danger_Dave
what will happen if you turn the idle mixture screws in as tight as humanly possible?
Old Dec 4, 2007 | 05:28 AM
LxMan1's Avatar
LxMan1
It should lean out and die from no fuel in the idle circuit.
Old Dec 4, 2007 | 05:35 AM
ford390gashog's Avatar
ford390gashog
You strip the threads and mash the needles.
Papas66
Apr 23, 2014 08:23 PM
gobblerman
96
Jul 31, 2010 01:05 PM
Hydrocarbon302
Aug 20, 2007 09:13 PM
joe460
Mar 22, 2006 09:56 AM
sharpassrazor
Feb 26, 2004 02:04 AM
