Cold temps, no start: UPDATE
Old Nov 29, 2007 | 02:35 PM
Chin Motorsports's Avatar
Chin Motorsports
'03 F350 SD Dually, 6.0 PSTD
FYI to the community... I posted here a few weeks ago about an unusual cold-start issue. Original post . Truck started normally, 100% reliable, as long as above 40 degrees. But, when colder, no-start. Well, it's been resolved. It wasn't batteries, block heater, starter, fuel, nothing under the hood. It was a $10 relay in the fuse panel under the steering column. Relay #307 in your owners manual. This relay was failing when cold. Another FTE poster suggested checking the relay, also.
My real beef - Ford dealer was NO HELP. I resolved this on my own. I told the dealer what I suspected, and asked them to service it. They responded that they couldn't do anything unless there was a failure code, and wanted to re-flash the PCM. They also said that there's no way anything under the dash would cause a no-start, and insisted on doing expensive stuff under the hood. I told 'em no-thanks.
Here's how I isolated the problem: On a recent cold night, I plugged in the block heater, and put a space heater on the driveway under the engine overnight. AM ambient is about 30 degrees, and everything under the hood is warm. Tested, and NO START. Cabin was at ambient, only under hood components were warm. So, I move the heater to the driver's floor, blowing on the fuse panel. After just 5 minutes, it fires up no problem. Then, next night, it's cold again. I remove the relay from the fuse panel, and bring it inside overnight. I don't plug anything in on the truck. AM, everything is icey, truck is at ambient, cabin and engine. I simply plug the warm relay back into the panel, light the glow plugs for 30 seconds, and it fires right up. Problem solved. Dealers, hope you're PAYING ATTENTION!
Old Nov 29, 2007 | 04:07 PM
Powermoon's Avatar
Powermoon
Good work Chin. Hopefully you didn't pay the dealership for looking over your truck and not solving anything.
Moon
Old Nov 29, 2007 | 06:25 PM
firesoutmatt's Avatar
firesoutmatt
What does the relay control ?
Old Nov 29, 2007 | 06:33 PM
wb6anp's Avatar
wb6anp
relay 307 is the a starter relay. As my wife just said that could do it.
Old Nov 30, 2007 | 12:12 AM
bismic's Avatar
bismic
A post from a long time ago suggested that pulling this relay may be the best (and certainly the cheapest) anti-theft device!! Wouldn't want to do it every time, but it makes sense if the truck would be parked for extended periods or in high risk areas.
Old Nov 30, 2007 | 12:48 AM
Chin Motorsports
Originally Posted by bismic
A post from a long time ago suggested that pulling this relay may be the best (and certainly the cheapest) anti-theft device!! ...
Hey, good idea... then again, my effective anti-theft device is the 32 foot race trailer that is constantly under tow!
Old Nov 30, 2007 | 06:49 AM
moebdick's Avatar
moebdick
You should relay all of this info to Ford when you do your customer satisfaction survey.
Old Nov 30, 2007 | 06:21 PM
bismic's Avatar
bismic
Ouch !!!!!!!!!!
Joshglov
49
Jan 9, 2019 12:31 AM
drjoe171
May 7, 2014 04:43 AM
Brads-idi
28
Jan 29, 2012 11:22 AM
Scout
Feb 4, 2010 11:44 AM
Turbo666
Jul 28, 2009 10:22 AM
