Over fueling ?
Old Nov 28, 2007 | 10:12 PM
brickie's Avatar
brickie
Over fueling ?
I have larger (Spartan tow)Injectors and sct street tune in the truck, stock turbo and straight exhaust.I need to tax my truck for payload on steep grades.The turbo cant make max boost (over fueling) can I cook a piston or two? The black smoke is thick at times and the power dissapears when a load is working the motor. I worry but is it hurting anything?
Old Nov 28, 2007 | 11:22 PM
MrMike06's Avatar
MrMike06
Im sure you could do some damage. What are your egts while pulling up the grades.
Old Nov 29, 2007 | 04:07 AM
LvTitan's Avatar
LvTitan
do you have an egt gauge ?? get one !! bigger injectors and stock turbo plus SCT will definitely melt a piston if you are not careful !!
Old Nov 29, 2007 | 06:52 AM
cgrayson9's Avatar
cgrayson9
Get a EGT guage NOW!!!! I have similar injectors and see EGT skyrocket if you pull a grade below 2,000 RPM's. You will destroy the motor!!!! I have to downsift and make sure the motor stays in a lower gear and then EGT's drop like a rock to a very safe level. At the higher RPM's, I get to enjoy all that new found power. You may want to consider a Snow kit and inject water/methanol. I have the kit and see a 200 degree drop when in use.
Old Nov 29, 2007 | 09:08 AM
brickie's Avatar
brickie
Thanks guys.You all confirmed what I thought.Ill put the egt guage (still in the box)in on the weekend.Matt if you read this before I talk to you I need a defuling tune to get me through to the rebuilt turbo.
dowboy93
Feb 13, 2015 07:55 PM
Griffin9
13
Sep 30, 2014 07:25 AM
rodneywar
May 20, 2012 06:36 AM
rollinblackcloud
15
Dec 28, 2011 01:44 PM
ohmar99
Dec 7, 2009 08:07 PM
