76 highboy
Old Nov 27, 2007 | 10:07 PM
Vinford's Avatar
Vinford
76 highboy
I was wondering if anyone knows how many diffrent diffs came in a 76 highboy?
Did some come with a dana 60?
If so what else did they come with?
Old Nov 27, 2007 | 10:21 PM
Mil1ion's Avatar
Mil1ion
Iirc,
3.54,
3.73,
4.10,
4.11
Old Nov 27, 2007 | 10:50 PM
Vinford's Avatar
Vinford
Thats the ratio right?
Im wondering about Dana 60 Dana 44 etc?
How many diffrent models?
Old Nov 29, 2007 | 08:00 PM
7866ford's Avatar
7866ford
should be a 60 rear and high pinion 44 up front. Very seldom you will find a 60 front but not likely.
Old Nov 30, 2007 | 12:30 AM
4starcstms's Avatar
4starcstms
depending on the GVW will depend on the Front axle... There were some with 60's thou ...
Old Nov 30, 2007 | 03:20 PM
sparky69's Avatar
sparky69
i think only low pinion dana 44's and dana 60's were availabe for the front axle until 1978. some '78 and '79 f-250 4x4's got the high pinion 60 if they had the snow plow package (an option, not stock), and all '79 f-350 4x4's had the high pionon 60 as stock equipment. 1979 was the 1st year a f-350 4x4 was available. in 1980 and later models the dana 60 was still used in the larger trucks, but the spring perch locations changed. this means that 80 and later dana 60's are not a direct bolt on swap. it can and has been done, but requires quite a bit of fabrication.
the high pinion 60's are more desireable (and expensive). the fact that they were only available in '78-79 f-250 4x4's as an option and '79 f-350 4x4's as stock equipment is the reason they are so hard to come by. expect to pay $1000 to $1500 for a rebuildable one if you can find one.
i have a 1977 hiboy with a low pinion dana 44HD in the front and have considered doing this swap, so please correct me if i'm wrong.
Old Nov 30, 2007 | 04:42 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
The 77 highboys had highpinion 44 fronts with disc brakes. Maybe even late 76 models. The 60s came in the slowplow trucks as sparky said.
dipstick429
Feb 12, 2015 08:59 PM
almost_nick
18
Jun 28, 2013 01:45 PM
db76highboy
New Member Introductions
Apr 16, 2013 08:23 PM
diesel_crawler
Feb 15, 2010 09:13 PM
76highboy
Feb 27, 2000 09:06 AM
