Power Pulleys
Old Nov 21, 2001 | 10:31 PM
jwtaylor's Avatar
jwtaylor
Power Pulleys
Old Dec 17, 2001 | 11:11 PM
MustangGT221's Avatar
MustangGT221
Power Pulleys
Does anyone make power pulleys for the 4.9L?
Old Dec 20, 2001 | 08:22 AM
Stephens's Avatar
Stephens
Power Pulleys
I give up, what's a power pulley?
Old Dec 21, 2001 | 08:10 PM
Nod's Avatar
Nod
Power Pulleys
Mustang, I looked for these pulleys for my 300 and e-mailed two online companys that make them and they both said no,I can't remember the names, good luck.
"bowties in the rearview mirror"
Old Dec 21, 2001 | 08:26 PM
StrangeRanger's Avatar
StrangeRanger
Power Pulleys
I had no luck either.
Old Dec 21, 2001 | 10:39 PM
youngster's Avatar
youngster
Power Pulleys
If your truck has a serpentine belt, the pulleys from a 302 should work fine. I bought a kit for the 302 and used the alternator and P/S pulleys . I didn't use the waterpump pulley but I know it fits on my 90. If you are in doubt, call someone like Summit Racing and verify the inside and outside diameters.
Old Dec 22, 2001 | 09:31 AM
brown 4x4's Avatar
brown 4x4
Power Pulleys
I'm curious too, what is a power pulley?
Old Dec 22, 2001 | 08:04 PM
StrangeRanger
Power Pulleys
Power pulleys are a set of replacement drive pulleys featuring a smaller damper pulley and larger alternator, water pump and sometimes power steering pulleys. They reduce the speed of the belt and further reduce the speed of the alternator and pumps.
This performs a couple of functions. First, it reduces the parasitic horsepower losses from running the alternator and pumps leaving more HP for moving the vehicle. Second, if you've done a gear ratio change they compensate by reducing the speed of the belt driven components at highway speeds.
They're a very common and useful modification to a 5.0 Mustang where the 3.08 gears have been replaced with 3.55 or larger
There is a down side, they reduce the charging rate, engine cooling and air conditioning capacity at low speeds, so if any of those areas are marginal, they can create a problem.
Old Jan 1, 2002 | 03:29 PM
ricekiller's Avatar
ricekiller
Power Pulleys
Any Luck With Finding the hi-perf pulleys...? i want a set of anodized aluminum ones..
Old Jan 1, 2002 | 06:11 PM
MustangGT221
Power Pulleys
No luck
