Exploder transmission
Old Nov 27, 2007 | 08:22 AM
woodly1069's Avatar
woodly1069
I have a 2003 Exploder with the 4.0 and an auto tranny. Where the heck is the dipstick for the stupid tranny? Any ideas are welcome. Thanks for ANY input...
Old Nov 27, 2007 | 10:23 AM
Exploder02's Avatar
Exploder02
No dipstick on these... its one of those "sealed" units. There is a procedure for checking the fluid, involves getting the transmission up to temp, then removing the small level check / fill plug that's inside the drain plug on the pan, and squirting some fluid in it (via a hose and pump), then letting it drain back down. Pretty annoying, and it seems every place I've taken mine (for tranny flush, etc.) has had to make multiple attempts at getting it properly filled up.
Ford's not the only maker doing this; it seems other manufacturers are doing the same stupid thing.
Old Nov 27, 2007 | 03:51 PM
danr1's Avatar
danr1
Yea I agree, very stupid setup. Anything that holds fluid needs a dipstick or some kind of easy to access method to check the level with.
From what I've been reading I think I stay with the older model, had planed on buying a newer one again. The 96 we have is just new enough to use OBD2 so I think we'll just keep it. Have very little if any trouble with it, went from a 91 to it and had thought of jumping up a few more years would be a good idea again, not so much anymore!
Old Nov 28, 2007 | 07:05 AM
steve(ill)'s Avatar
steve(ill)
go partway donw the post and read how to change the oil--- not that bad.
https://www.ford-trucks.com/forums/6...t=transmission
ostrx250
Apr 27, 2013 08:34 AM
sixpack2639
Aug 18, 2011 03:19 AM
rbloodhound
Offroad & 4x4
Mar 12, 2008 02:10 PM
Steven@nd
Jul 19, 2004 01:58 PM
Batonboss
Apr 16, 2003 07:37 PM
