Truck Lost Engine Power (HELP)
Old Nov 27, 2007 | 01:50 PM
03_PSD's Avatar
03_PSD
ricks right remember that pan or you'll have a huge mess, trust me, personal experience!
Old Nov 27, 2007 | 02:45 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I did it the other day, what a mess. lol
Old Nov 27, 2007 | 05:56 PM
KSims1868's Avatar
KSims1868
Well...it is the Fuel Pressure Reg thing on the bottom of the fuel pump.
Old Nov 27, 2007 | 06:35 PM
Pocket's Avatar
Pocket
Huh? Are you saying that you aren't getting any fuel? Or are you asking if the regulator is on the fuel pump?
The regulator is on the driver's side of the fuel bowl on the top of the engine. It's located inside the cap right where the fuel return line plugs into the bowl. The regulator shouldn't be the issue since those are pretty foolproof for failure. The spring inside gets weaker over time, but they don't generally go out all of a sudden.
Old Nov 27, 2007 | 08:42 PM
KSims1868's Avatar
KSims1868
I might be saying the wrong thing.
It is something (switch, sylinoid, etc..) located at the bottom of the fuel pump. That's how it was described to me at least.
Does this make any sense to anyone?
Old Nov 27, 2007 | 08:57 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Not to disagree but a better way to check the fuel flow is to open the filter lid and make sure it is full. If it is, you at least have some flow. If not, there you have it. Next, close it up and place a suitable container under the drain valve line that "YOU DO HAVE A HOSE ATTACHED TO RIGHT". Open the valve behind the bowl and let the bowl drain. When it stops, turn the key to the WTS position and observe for flow indicating the pump is trying to fill the bowl. Not a trickle, a flow. If not, problem. Remember, the pump will only run for about 30 seconds or so unless you start it or switch the key back off then on.
Old Nov 27, 2007 | 09:02 PM
Tenn01PSD350
Uhm no. Who told you that? There is no such thing. There is a reset switch behind the passenger kickpanel and a regulator on the side of the fuel bowl which when it fails will lead to excessive pressure and premature pump failure but I highly doubt this is your problem. Aside from that it is fuses and wiring.
EDIT: to put your mind at ease, the pump is mounted on the inside of the frame rail under the driver seat. Have a look. If you find that thingy you're talking about let us know.
Old Nov 27, 2007 | 09:25 PM
KSims1868's Avatar
KSims1868
This is what a mechanic is telling me. He was referred to me by a friend, and is supposedly a trusted guy that has done a lot of work for him.
I need to call him in the morning to go over again exactly what he is saying he's replacing.
I'll post again in the morning to tell you exactly what he says. I don't want to get screwed!!
NorthCarolinaExpy
15
Mar 6, 2015 10:08 AM
ss27gogeta
Feb 20, 2015 09:16 PM
powerstroke cowboy
Jun 3, 2013 02:08 AM
styleside96
1997 - 2003 F150
Nov 19, 2012 09:37 AM
Phoenixson
Oct 7, 2008 11:09 PM
