a/c Compressor Q's
Old Nov 26, 2007 | 06:54 PM
03_PSD's Avatar
03_PSD
a/c Compressor Q's
I'm about to beat this to death. I'm still dealing with no heat. So far what I've done is change to the 203* stat and billet housing, still no heat. I have felt the heater hoses and they are hot, were hot before the stat change. One thing I have noticed is that the a/c comperssor runs all the time, even when just on vent. Don't really know what else to check. Seems I'm always turning wrenches now, but well worth it when I can save some money.
Old Nov 26, 2007 | 07:36 PM
F350-6's Avatar
F350-6
I'll have to check mine tomorrow if no one else chimes in. I know the compressor will run on vent when it's pointed toward the cold side, but I thought it shut off at some point on the hot side.
Thermostats and housings should not affect operation of the heater. Do you get warm air or just outside temperature air? To me it sounds like you have an issue with your switch. Have you checked the heater core (behind the glove box) to see if your getting hot fluid through there?
Old Nov 26, 2007 | 08:02 PM
03_PSD's Avatar
03_PSD
the a/c compressor does not cut off when switch is on heat. there is no heat at all....compressor runs continuously whether the switch is on cold or hot, always cold air comming through the vents. i'll have to check the heater core tomorrow. what should i look for on the heater core, see if its warm?
Old Nov 26, 2007 | 08:08 PM
medhvac's Avatar
medhvac
unplug your compressor and see if the heat works then!
Old Nov 26, 2007 | 08:12 PM
F350-6's Avatar
F350-6
Yes, the heater core is basically like a mini radiator. The hot coolant is pumped through it and air is blown accross the coils to provide heat. You could probably check it from the engine compartment too. There will be 2 rubber hoses approximately 1" diameter going to the heater. One is supply, the other is return. If both of them are hot after the truck warms up I'd say you have a switch (****) issue.
I'll check tomorrow if my compressor runs at max heat on vent setting.
Old Nov 26, 2007 | 08:39 PM
03_PSD's Avatar
03_PSD
i thought i saw one another thread that there is a switch or door that opens and closes to allow heat or cold to pass. how can you tell if that is bad or is it the switch that tells it whether to open or close. i think it is called a door blend or something???
i'll try to unplug the compressor and see about that but wouldn't the air seem somewhat warm even if the compressor was still on when switched to heat. right now cold air is comming out no matter which position the switch is in.
Old Nov 26, 2007 | 08:52 PM
dvfd12's Avatar
dvfd12
Possible vacuum leak? Just a guess.
Old Nov 26, 2007 | 08:57 PM
F350-6's Avatar
F350-6
Insufficient, erratic, or no heat
• Low engine coolant level.
• Engine overheating.
• Plugged or partially plugged heater core.
• Temperature blend door binding/stuck.
• A/C electric blend door actuator.
• Incorrect heater control valve operation.
PM me your email address and I'll send you more information than you want on what to look for according to the service manual.
Old Nov 27, 2007 | 04:11 AM
Green_Dually's Avatar
Green_Dually
Maybe the blend door isn't working.
Old Nov 27, 2007 | 05:49 AM
F350-6's Avatar
F350-6
I checked mine this morning. With the vent turned to full heat the compressor was not running.
Old Nov 27, 2007 | 08:37 AM
03_PSD's Avatar
03_PSD
i got your email, really appreciate it Chris. i'll look it over and see if i can make heads or tails of it. thanks
fbh31118
67
Jun 19, 2014 01:24 PM
Vernon_04_Expy
May 7, 2004 12:06 PM
stangz
Nov 21, 2002 10:52 AM
